Old 12-03-2019, 10:33 AM   #1
rmcelroy
Drives: 2013 FR-s
Home brew front pipe
I swapped my stock front pipe with a resonated pipe. Now the car stutters a little when I pull away from a stand still. It just happens when I start off with a very light throttle.
I have the OFT 2 tune because I run a UEL header, I was hoping the OFT would learn about the cat delete and adjust, but its been 4 days now and its still stuttering.
Would a leak cause it, I installed it myself. The borla muffler in this picture was swapped for a Vibrant 1792 resonator for clearance issues with the AT pan.
rmcelroy is offline   Reply With Quote
Old 12-03-2019, 12:31 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
if you have a leak pre-O2 sensor ( headers) then it could explain a poor running condition. At the front pipe I wouldn't expect it to cause any issue except additional sound and a stink
Old 12-03-2019, 01:44 PM   #3
Timmy_Jones
Spun
Drives: 23' Supra
Maybe a longshot...but is it rubbing somewhere and causing ping or knock in the engine?
Timmy_Jones is offline   Reply With Quote
Old 12-03-2019, 06:51 PM   #4
rmcelroy
Drives: 2013 FR-s
I had to clearance the resonator a bit. It may still be up against the AT pan. The engine does sound different-but I though it was just the new pipe sound.
Old 12-04-2019, 09:48 AM   #5
wparsons
wparsons's Avatar
Removing the secondary cat won't effect the ECU at all, the O2 sensors are both ahead of the front pipe (before and after the primary cat in the header).
Is it possible you're just trying to use less throttle because it's louder than before, and needing more throttle to pull smoothly?
flickr
Old 12-04-2019, 10:10 AM   #6
rmcelroy
Drives: 2013 FR-s
You are probably correct, I guess I just need to use WOT all the time:>
Old 12-04-2019, 12:37 PM   #7
HaXx
Drives: jrsc_brz
catless front pipe makes the exhaust gasses smell? does the same go for catless headers?
HaXx is offline   Reply With Quote
Old 12-04-2019, 01:37 PM   #8
rmcelroy
Drives: 2013 FR-s
Not really. The header may have caused some odor, but my sense of smell is not perfect. The front pipe is definitely rotten eggs!
Old 12-04-2019, 02:38 PM   #9
DarkPira7e
DarkPira7e's Avatar
Haha no, but if you have a leak you're going to get more exhaust smell in general because it's exiting under the car, not behind it.
Old 12-05-2019, 09:51 AM   #10
wparsons
wparsons's Avatar
It's a total lack of cats that makes it stink. A catless front pipe with the stock header won't smell at all because there's still the stock cat in the header. A catless header with the stock front pipe won't either because there's still the stock cat in the front pipe.
flickr
JDL 3" Over-Pipe/Front-Pipe Combo-Pipe SOLD Jbelmonte Engine, Exhaust, Bolt-Ons 3 03-08-2018 09:00 PM
WTT Invidia catless front pipe for a resonated/catted front pipe nickmerronesucks Want-To-Buy Requests 3 05-10-2016 02:25 PM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 01:42 PM
Home brew trunk mod idea JarredH Cosmetic Modification (Interior/Exterior/Lighting) 7 10-16-2013 02:43 PM
