Old 11-25-2019, 06:17 PM   #1
Nitemare15
Drives: 2015 Scion FR-S
Stage 1 Brake Kit FT86SpeedFactory
Hey guys, I'm new here!
I just recently got a 2015 FR-S, the brake pads are going to need to be changed and it's looking like I'll need new rotors/have them resurfaced. Since I'm having to do this I figured I'd upgrade the brake system for more stopping power (want to install a supercharger kit in the near future). I was looking at FT86SpeedFactory's Stage 1 kit. Is this a good option to go with? I did a bit of research and I'm looking at that kit with the Ferodo DS2500 front/rear pads. Any suggestions feedback for going this route?
Nitemare15 is offline   Reply With Quote
Old 11-25-2019, 06:25 PM   #2
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
My setup: Carquest Platinum Fr rotors, cut stock rears, WINMAX W3 Pads all around. Stoptech SS lines and BG Dot4 fluid. FLUSH YOUR BRAKE FLUID NO MATTER WHAT.
It should be plenty. I could lock my front tires at 50mph with little effort. I had 245 Conti Extreme DW on at the time. Theres a bit of squeal now and then, and the dust is about a high-medium. 6-7/10
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 11-25-2019, 06:55 PM   #3
Nitemare15
Okay awesome, I'm not looking to track my car right now. But in the near future I'm seriously debating it. I do some spirited driving and I figured that the package would be overkill. But I also thought about the upgraded power in the near future. Thank you for the quick response
Old 11-25-2019, 09:42 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
What upgraded power? A BBK isn't really going to change how fast you stop... That's mostly in the tires, a little in not having garbage pads. A BBK will still work after multiple hard stops on a track longer, comparing the same pads and tires on both...
ABS keeps you from locking up, but the stock brakes are quite capable.
Centric blanks, and the DS2500 is a good street/autox pad (I've used them on track sprint too). Probably OK starters on track but easy to outgrow.
The Following 3 Users Say Thank You to cjd For This Useful Post:
Goingnowherefast (11-25-2019), Pat (11-26-2019), strat61caster (11-25-2019)
Old 11-25-2019, 10:57 PM   #5
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Like mentioned, pick up some good pads (DS2500, Porterfield R4S's are a good dual duty pad, especially for starting track work), centric blank rotors, and new DOT4 fluid. That's all you need.
Like mentioned a BBK doesn't so much increase stopping power (that is pads and tires), but more increases the heat capacity of the braking system (only needed for track work).
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 11-26-2019, 11:19 AM   #6
Nitemare15
I plan on adding a supercharger within the next year or so. I figured I need better hardware (better pads, rotors) to deal with the additional power. That's what I meant by the added/upgraded power.
I'm very new to this whole platform/performance car thing. If my thought processes on how these things work is wrong please correct me.
Old 11-26-2019, 12:25 PM   #7
Westen86
Purist
Westen86's Avatar
Basically, unless youre tracking 400hp, or putting a 2J in it, good pads and fluid goes a long way. Counter Space Garage sells street pads for $300+ an axle. My WinMax were $135 an axle. My only advise when shopping is avoiding a dedicated autocross pad. The fluctuation in friction might catch you off guard, especially on track.
RRRacing Stage II Willwood kit - Brake pads Takumi788 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 07-06-2019 10:58 AM
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 02:38 AM
Winmax W1 Stage 1 Brake Pads - $100 Shipped klittl06 Brakes, Suspension, Chassis 9 06-28-2017 08:18 PM
FS: Winmax W1 Stage 1 Brake Pads bobsacamenoh Brakes, Suspension, Chassis 6 04-26-2015 12:44 AM
WORKS Stage 1 Complete Brake Package Upgrade 86_ZN6 Brakes, Suspension, Chassis 1 05-28-2013 04:57 PM
