Old 11-20-2019, 03:57 PM   #1
zakman16
zakman16's Avatar
Drives: Man
Send a message via AIM to zakman16 Send a message via Yahoo to zakman16
brz no crank and no power to starter
my 2013 brz push button wont crank everything in and out of the car works (gauges,lights etc) also the starter,battery key fob,ecu,fuel pump and clutch switch are all working or have been replaced.
ive visually checked all the fuses and relays and switched some around with ones that i know worked but still have no power to my starter any ideas what is could be?
mods:
header back exhaust
tail lights
led fog lights
sub woofer
oft tuner
rocket bunny rear diffuser
zakman16 is offline   Reply With Quote
Old 11-20-2019, 04:18 PM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Did you check for codes? Direct wire the starter with the ign on to test the starter?
Check live data in obd2 if it shows clutch switch, etc. I never checked on these cars for that..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-20-2019, 04:34 PM   #3
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
could it be the security immobilizer, check the info in this thread to rule that out:
http://www.ft86club.com/forums/showthread.php?t=120838
DandoX is offline   Reply With Quote
Old 11-21-2019, 01:19 AM   #4
zakman16
zakman16's Avatar
Drives: Man
No codes like engine lights or anything but the dealer said I had fault codes in my ecu (probably from the starter circuit) but I got a used ecu for 100$ and got it flashed into the car and still the same thing is happening.
And where is the immobilizer located and how would I trouble shoot it?
Old 11-21-2019, 04:58 PM   #5
DandoX
Senior gif poster
DandoX's Avatar
I gave you a super handy link to the forum thread that should be able to answer most of your questions regarding the immobilizer, the member who posted had a very similar issue that you describe, check out the link below:
Old 11-23-2019, 08:08 PM   #6
zakman16
zakman16's Avatar
Drives: Man
update
i just want to point out i had the exact same issue 4/5 months ago the only difference was if i kept pushing the push button the car would eventually start and when it did i got a engine light with a P0512 code (i dont think its my push butto cause it cycles on accessory and off no problem) i didn't mention this before cause i couldn't remember what code came up cause i cleared it and never had the issue again. but it was for sure P0512 i dont have an engine light this time around but i think thats cause i haven't got it to start yet.
brz, no crank, no start, push button start
Car clicks but won't crank. Battery or Starter? JERM^ Issues | Warranty | Recalls / TSB 93 09-14-2019 10:11 AM
Agency Power Crank Pulley Chillz Engine, Exhaust, Bolt-Ons 6 05-23-2013 08:25 PM
PURE POWER PACK- The Perfect Starter Kit For Your 86!! Pure Automotive Engine, Exhaust, Bolt-Ons 22 03-19-2013 06:58 PM
Agency Power Crank Pulley JDMrolla Engine, Exhaust, Bolt-Ons 6 02-23-2013 07:23 AM
Agency Power Crank Pulley Chillz Engine, Exhaust, Bolt-Ons 2 11-30-2012 03:45 AM
