Old 11-19-2019, 02:38 PM   #1
HaXx
Drives: jrsc_brz
Critique my Widebody plans/budget
Im trying to do as much research as possible, and ask as many questions up front so i can maximize having to buy parts once, right the first time.
im not trying to slap a list together in my mind and have everything go terribly wrong, so im reaching out to those who know, and have more experience than i do
as its going to be static so im not looking to slam it to the ground, but im not a performance driver so i dont need racing parts that would make trackies mouths water. any critique is appreciated, what im getting right, what ill want to reconsider, and anything i completely omitted.
1. THE KIT
Rallybacker v2 16pc (purchased)------------------------$2000
Professional install (quoted)------------------------------$2000
Painting kit to existing oe color-------------------------$2000
2. PLATFORM & HANDLING
fortune auto 500 9k/8k (purchased/installed)-------------$900
wtb used rlca's and toe arms ------------------------------$500
3. WHEELS + TIRES
18x10.5 +15 and spacers--------------------------------------$1600
or
custom 3p-------------------------------------------------------$3000
Tires-----------------------------------------------------------$550
im trying to be conservative/high with my estimates, i know i could get bc coils for 500, and used lca's for much less, xxr's for $800, but i want to buy nice, not twice.
i researched a ton, and did lots of budgeting before getting a JRSC installed and dyno'd and it payed off when it came time to pull the trigger.
im not saying this is the only way i want it done, im willing to spend more, i want to do whats right, and im reaching out to you for advice.
HaXx is offline   Reply With Quote
Old 11-19-2019, 02:48 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Do you work in accounts or budget setting department?
Old 11-19-2019, 02:52 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I promise if your goal is to buy nice, not twice, you should not buy used suspension components. For what you're spending, just buy new. Step down on your coilover preference unless you're trying to track the car (The KW V1 or ST coilovers are perfect)
If you're planning on going really low, especially with the power you're making, I'd budget in to afford axles fairly often.
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
HaXx (11-19-2019), norcalpb (11-19-2019)
Old 11-19-2019, 03:01 PM   #4
norcalpb
norcalpb's Avatar
Also going used for axles is pretty smart. I bought used 2015 axles for $180 shipped whereas they would’ve been $800 + tax from the dealership
Old 11-19-2019, 03:15 PM   #5
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
$1000 for paint seems way off.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
HaXx (11-19-2019)
Old 11-19-2019, 03:31 PM   #6
86MLR
86MLR's Avatar
Double or triple your budget for install work if you want a good job.
I know of a wide body build that cost around $10k, that was install and paint, body prep prior to kit install takes alot of time to do right.
Unless you just do a hack job like most wide body installs.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 11-19-2019, 03:44 PM   #7
Milhouse86
Noob
Milhouse86's Avatar
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
That's a good start. I would double the paint and install budgets. Prepare for the worst and let your surprises be good. I know you think you passed the number but not nearly enough.
Suspension I agree with whoever above said downgrade. If your not tracking and just want a slight drop why not RCE yellows?
Stock car really has a great setup for daily. Definitely do not pay $2k for coilovers unless you want to go tracking/autocrossing whatever. Or if you have enough money you don't care.
Sent from my Pixel 2 XL using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599
-1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black
Milhouse86 is offline   Reply With Quote
The Following User Says Thank You to Milhouse86 For This Useful Post:
HaXx (11-19-2019)
Old 11-19-2019, 04:33 PM   #8
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Used $1500-$2000 coilovers (rce's or csg flx a's) -------------$1500 These are gonna be a little soft, you'll probably want something atleast 9k spring rate range
used rlca's (ideally spl's?) and toe arms -----------------------$750
3. WHEELS & TIRES
Your wheel specs are way off. I suggest you sit down and do some math on what offsets you need. I can give you a general starting point. You'll want around 18x9.5 -10 ish on the fronts and around 18x11 -25 ish on the rears.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
The Following User Says Thank You to Soloside For This Useful Post:
HaXx (11-19-2019)
Old 11-19-2019, 05:04 PM   #9
86MLR
86MLR's Avatar
2k for coils is fair to me, for 2k you can get performance and comfort.
I don't track this thing but coils let me choose my drop, 20mm, and they came with adjustable top hats.
My MCA street performance coil overs piss on the OEM Sachs for performance as well as comfort.
https://mcasuspension.com/products
I would spend my money on handling before huge rims and tyres. But then I don't even like wide bodies and/or big rims on cars that don't need the rubber.
How long will the body work last before rusting out is another factor to look at, plus lose of value at resale.....meh
The Following User Says Thank You to 86MLR For This Useful Post:
HaXx (11-19-2019)
Old 11-19-2019, 05:19 PM   #10
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
I have a set of nice AST 5100's with camber plates id sell for 2000. helper springs and huge adjustment with ride height and dampening
Clutch Dog is offline   Reply With Quote
Old 11-19-2019, 05:20 PM   #11
Clutch Dog
Originally Posted by 86MLR View Post
Double or triple your budget for install work if you want a good job..
also this
the trick with wide body-ing a car is getting that fender clearance. youll want a semi decent cut to weld up the body again, but its not just weld. its weld, seam sealer, primer and then paint. then you want to make splash guards for the kit too. all that is custom work and takes time and money to do it right
Old 11-19-2019, 05:27 PM   #12
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
I had my rocketbunny v2 installed for $2000 looks great
But i agree, double your paint budget
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
HaXx (11-19-2019)
Old 12-10-2019, 11:15 AM   #13
HaXx
Drives: jrsc_brz
little bit of an update:
the kit has arrived from japan
rallybacker v2 --------$2100 shipped (black friday 10% 0ff)
paint---------------------------$2000 (have not had an estimate yet)
install--------------------------$2000 (qoute from literally the nicest shop i could find, EASTSIDE MOTORING 10+ widebody installs personally done by the tech im speaking to, but they dont do paint there)
coils -------------------$900 second hand fortune auto includes toe extension arms
rlca----------------------------$3-500 still looking for used ones
18x10.5 wheels-------$1600
ss595 255/35-----------------$400
spacers------------------------$whatever
total------------------~$9,500
thats without custom 3p wheels. and cheap tires. i dont really dig 3p. im still liking the gold pf01
im using wheel it fit, but finding that real world measure are drastically different so im going to try a bunch of stuff on at the shop and see what i actually want
for a while i was considering trying it on lowering springs but i was like jesus f, ill just save up another two months and do it right.
Old 12-10-2019, 02:31 PM   #14
Soloside
Save up a little more and buy 3P wheels.
Or you can just buy my car XD
2014 Subaru BRZ
Please critique the performance of my car. What would you add/drop/change? stockysnail Northwest 14 08-22-2015 01:42 PM
Critique My Budget Build Wolfdogelite Electronics | Audio | NAV | Infotainment 10 04-05-2015 02:27 PM
Part critique please Calum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 09-28-2013 05:40 PM
Please critique my suspension mod list autogyro Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-27-2013 08:08 AM
Major road trip to pick up my SWP Premium starting Friday 6/15. Critique my course. Mitch BRZ First-Gen (2012+) — General Topics 28 07-12-2012 04:30 PM
