Old 11-19-2019, 02:41 AM   #1
Nitrozedezz86
Nitrozedezz86's Avatar
Drives: Ft86
Exclamation Hearing a rattling noise everytime I pass over rough roads
I’m not sure what needs changing or tightening. But I’m hearing a rattling noise everytime I go over bumps on the road. Someone said it had to be the steering rack and the reason being is because the steering rack needs to be greased.
They mentioned drilling hole into the rack to insert the grease and putting grease nipples. Can someone advise me on this .
Thank you.
Nitrozedezz86 is offline   Reply With Quote
Old 11-19-2019, 05:21 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Where is the noise coming from? How loud is it? Does it sound more like plastic or metal? What modifications are done to your car? What size wheels/tires? How fast are you going over these bumps? How many miles on your car? Do you hear this sound under any other circumstances?
Steering rack is the last place I'd be searching.
Old 11-19-2019, 11:10 AM   #3
humfrz
^ this.
Welcome to the forum, Nitrozedezz86 -
humfrz
Old 11-19-2019, 11:50 AM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Check all suspension components (shocks, top hats, control arms, sway bars, end links, and all the bushings) first.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 11-22-2019, 05:01 PM   #5
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Noise over bumps? Most common component failures are sway bar links and the sway bar frame bushings. That is more of a clunk though, not so much rattle.
Strut tops, control arm bushings, ball joints.
I've never seen a steering rack cause a rattle.
Don't drill into anything in an attempt to add a fitting and grease. Unless you can get out the metal shavings you just created by drilling you're only going to make it worse. When you replace parts, buy ones you can grease if you want that ability. Moog comes to mind.
Rattles come from loose metal like brackets, exhausts, heat shields and whatnot.
Could also be caused by poor installation of new components. Think a shock bolt that didn't get tightened enough. It may become loose enough that a washer is now bouncing around between the shock bushing and nut.
Edit: If you want to add grease to an ungreaseable joint get a grease gun and get the needle looking attachment. Pierce the boot and add grease. Not as effective as a real fitting but might help.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 11-23-2019, 03:49 PM   #6
norcalpb
norcalpb's Avatar
I wonder if you’re having the same “bag of rocks” sound I’m having whenever I go over bumps.
Shakes the shit of my transmission tunnel
Old 11-23-2019, 07:19 PM   #7
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Thank you.
sounds like someone is making fun of you for whining about a rattle in a $25k sports car.
like everyone has mentioned, just tighten everything.
Old 11-25-2019, 10:59 AM   #8
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Check all heat shields first in exhaust. Then all suspension parts. Doubt it’s the rack.
Ernest72 is offline   Reply With Quote
Old 11-25-2019, 11:24 PM   #9
ermax
ermax's Avatar
There is a rubber coupler that sits between the EPS motor and the worm gear that will completely disintegrate leaving you with metal to metal contact. The EPS unit sits directly on the steering column between your knees. Took me months of checking bolts all over the place to find the source. If it’s the EPS coupler you will hear in on roads with small high frequency bumps at low speeds or while heavy braking at any speed. A good test that’s easy to reproduce is to run over road reflectors. The sound will seem like it’s down by you feet. I actually thought it sounded like it was coming from the passenger foot well and my son was convened it was coming from my footwell.
Long story short the coupler is a $5 part and is easy to replace. Search for a thread started by me with the word “coupler” for a DIY tutorial.
grease, rattling, shocks, steering rack
camber plates and rough roads question. 7 skulls Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 11-18-2017 05:05 PM
Rattling noise Eighty 6 Scion FR-S / Toyota 86 GT86 General Forum 4 06-07-2016 11:54 AM
Steering clunk over rough roads 73TORANA! Issues | Warranty | Recalls / TSB 39 12-05-2014 07:52 PM
Borla UEL rattles over rough roads? SloS14 Engine, Exhaust, Transmission 7 10-05-2013 01:03 PM
Hearing a ticking noise when slowing down to a stop with fan and/or AC on itisthumper Issues | Warranty | Recalls / TSB 1 07-18-2013 09:34 PM
