Old 11-16-2017, 08:52 PM   #1
7 skulls
Drives: 2014 scion frs
camber plates and rough roads question.
I have been searching and reading since I am considering getting Vorshlag High caster camber plates with oem perches to solve outside edge wear on my MPSSs. I know crash bolts are another opinion. But the roads around here are crap and I am concerned about slippage. Are camber plates prone to sliding loose in their adjustments?
I figure I can have my camber set at 1.5 neg camber and have my toe centered in its stock spec. That way I can adjust the camber as needed while keeping the toe in its range. All I have read states that on these cars toe does not change much with camber adjustments. Thanks.
7 skulls is offline   Reply With Quote
Old 11-16-2017, 09:46 PM   #2
Racecomp Engineering
Camber plates generally won't slip.
Worth noting that if your roads are really crap you will notice a difference in ride quality with the plates.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Ultramaroon (11-16-2017), wparsons (11-16-2017)
Old 11-16-2017, 10:08 PM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
I've, um... well, let's say I've tested some slightly extreme conditions. Zero slipping on my Raceseng camber plates. For that matter, none on the Tein plates on some roads that made me wish I was driving a boat... Brutally painful.
I have had camber bolts slip, though on a different car (I've never run them on this platform.)
Old 11-16-2017, 11:50 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
- Andrew
How about average crap roads?
Old 11-17-2017, 03:17 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
My answer to this were powerflex bushings PFF69-801G (or PFF69-801GBLK). They (in addition to SPC & Whiteline camberbolts in both lower strut holes) allowed me to keep stock rubber topmounts for NVH sake on crap roads, while get -3 camber front at stock height. Given even more camber due natural camber gain if car is lowered, imho should be sufficient for somewhat even wear on track, as -3 to -3.5 seems commonly mentioned as dialed camber for HPDE purpose alignment.
Of course one still needs rear LCAs to up camber there too.
P.S.
Given that you wish just -1.5 camber, that should be doable with just one camberbolt set, eg. SPC's. Adding Whiteline's camberbolts to these will up max camber to -2.2. And powerflex bushing to -3.
The Following User Says Thank You to churchx For This Useful Post:
7 skulls (11-17-2017)
Old 11-17-2017, 07:36 AM   #6
7 skulls
Thanks for the replies everyone. Ride quality is a good point. The Vorshlag perches allow for the use of all the stock components including the OEM rubber spring isolator so it should be similar to stock for ride.
The Following User Says Thank You to 7 skulls For This Useful Post:
~el~jefe~ (11-19-2017)
Old 11-17-2017, 11:33 AM   #7
P.S.
I know we've talked about these before, but do you have a picture of them installed?
- Andrew
Old 11-17-2017, 11:34 AM   #8
If your roads are averagely crap you will probably still notice them. The roads here range from kinda crap to really crap
The good camber plates will be quiet, but compared to OEM rubber mounts there will always be a change in harshness.
- Andrew
Teseo (11-18-2017), Ultramaroon (11-17-2017)
Old 11-17-2017, 11:35 AM   #9
You will still notice a change, as you're taking out the OEM rubber top mount.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
7 skulls (11-17-2017), Ultramaroon (11-17-2017), ~el~jefe~ (11-19-2017)
Old 11-17-2017, 11:49 AM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I know camber bolts can slip but I have not experienced it yet on this car. I run SPC in the lower hole and OEM crash bolts in the upper hole. I drive roads that are bad enough to bend one of my TE37s and one of my camber plates on my old coilovers (it mushroomed and had to be hammered out of the strut tower). I seem to have more problems with toe getting knocked out of spec.
Might be worth it to try bolts (and ensure they are properly torqued) instead of adding NVH from camber plates given that bolts are so cheap.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
7 skulls (11-17-2017), Racecomp Engineering (11-17-2017)
Old 11-17-2017, 12:31 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Nope. I'll try to remember when it's daylight again to seek some estacade to take pics from below, but no promise. Though imho there is not much to gain in seeing them installed, just instead of stock rear bushing of front LCA, which you probably seen plenty, a bit more stiff polyurethane one with eccentric metal insert with teethed end that can turned with supplied tool. Construction wise it's simpler to see looks of them unmounted. From things to note, shop, that did install of them, told that on one side that tool was unusable to reach for turning, so they just used screwdriver and hammer instead to turn . First dialled at max neg. camber position of these bushings, tightened, then dialled extra camber and fine adjusted it even both sides in normal way, using camber bolts. During install front bushing was replaced too (with whiteline's, for extra caster (PF's #1, WL's #2). As original bushings where removed using press, i guess it might be a bit harder for DIY vs just camberbolts. Still, i find it as do it once, set & forget item. For realigning in future in imho easier to reach and a bit finer way there are camberbolts too after all. Just that now camber range is moved slightly more negative, and that's done w/o slotting or having to resort to camberplates with pillowball mount. When whiteline failed with making non-binding Com-C mounts, they could have made this bushing too instead.
Old 11-17-2017, 10:21 PM   #12
Ultramaroon
not playing cards
- Andrew
All kidding aside. I've been waffling between slotting and installing plates for over a year. I don't see a good argument for camber plates.
Racecomp Engineering (11-18-2017)
Old 11-18-2017, 04:59 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
Ultramaroon: Given how i now can get wished camber also by other means, imho main pro argument left for camberplates might be relative ease of on-site DIY camber adjustment. I don't care about such, just keep driving with one alignment, so that isn't worth much for me. Also, how much camber do you need and are you lowered or not? Maybe you can get by w. those PF bushings too instead of slotting?
Ultramaroon (11-18-2017)
Old 11-18-2017, 02:48 PM   #14
Ultramaroon
not playing cards
I have been following the suspension discussions since I started here. My goal is to get that magical -3 degrees plus a little wiggle room out of my bone stock suspension using the least invasive technique possible.
Teseo (11-18-2017)
FS: HVT Non-raising camber plates & WL camber bolts trippinbillies40 Brakes, Suspension, Chassis 1 05-16-2015 09:00 PM
Steering clunk over rough roads 73TORANA! Issues | Warranty | Recalls / TSB 39 12-05-2014 07:52 PM
Borla UEL rattles over rough roads? SloS14 Engine, Exhaust, Transmission 7 10-05-2013 01:03 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
Camber Plates delusional Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-30-2012 08:17 PM
