Drives: Steel 2015 Frs automatic
Pedders Ezfit
Anyone ever run this or know much about it, I have scoured the internet and found like 1 review, they seem better than going for cheap coilovers for the 1in drop I want.
#2 |
Rust bucket enthusiast
What are you really looking for in a coilover if you only want a 1" drop? You know that the Eibach pro kit and several other spring companies give you the same drop on OE suspension right?
#3 | |
These are what he's after, completely assembled already. https://pedders.com/collections/suba...z-2012-present OP, I wouldn't suggest getting those at all. Shocks will be worse than stock, upper mounts will be cheap, who knows what the spring rates are, etc.
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | DarkPira7e (11-04-2019), Summerwolf (11-04-2019) |
#5 |
Panda Trueno
Drives: No twin now.
Why go this route when there are quality pieces available for lower or like cost?
| The Following User Says Thank You to Summerwolf For This Useful Post: | wparsons (11-05-2019) |
#6 |
Those don't include upper mounts, but you're not far off. New mounts would push it over $1000 for OEM or Group N mounts.
#7 | |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#8 |
Technically correct!
Shameless plug (slide 5 onwards): https://www.instagram.com/p/B4DFiFBg...d=7jfd2qhtfarn - Andrew |
| The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#9 |
Drives: 2013 Scion FRS manual transmission
install of Pedders FRS coils and struts
I just had all four struts replaced with the Pedders ezfit kit on my fairly high mileage (94k) FRS.
full disclosure: this is a daily driver, I've never raced on a track, so take that for what it is worth Immediate and dramatic improvement in handling. Stiff, but incredibly well damped. I don't plan to take advantage of the camber range of adjustment. My mechanic was impressed and told me to expect improved chassis feel and, gosh, he was right. Jack
| Pedders top hats and subaru camber bolts... results. | 7 skulls | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 58 | 02-01-2021 06:24 PM |
| Pedders offset front strut mount? Any knowledge? | 7 skulls | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 03-20-2019 03:20 PM |
| Pedders Top Hat w/ Camber & Caster Offset - Anyone with experience? | Jamestl | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 11-16-2018 04:35 PM |
| Pedders Suspension Now Available At RallySport Direct | RallySport Direct | Brakes, Suspension, Chassis | 9 | 10-17-2016 06:37 PM |
| New Pedders Coilovers for the BRZ and FR-S! | RallySport Direct | Brakes, Suspension, Chassis | 4 | 06-11-2013 05:42 PM |
