Old 11-04-2019, 10:21 AM   #1
MX-5RACER
Drives: 1999 Miata
SPC Lower rear control arm bolt
This past weekend, I went to adjust my rear camber after installing front camber bolts. When retorqueing the rear adjustment bolts, the driver side bolt stripped. I ended up making a bolt using a bolt from my spares, but I would like to replace the bolt with the correct one. Does anyone know the part number for the replacement bolt and nut from SPC? I cannot find it on their website and they have not responded to my email yet.
On a side note, the bolt looks very similar to a Miata alignment bolt. If I can dig up an old spare that I had for my Miata, I may try to use that bolt instead.
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
SPC Lower Control Arm 67660 cam bolt position? evil_1998 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-06-2019 11:06 PM
FS: OEM Rear Beam Brace and Rear Lower Control Arms zeal86 Brakes, Suspension, Chassis 9 08-23-2016 09:05 PM
Rear lower control arm dim theGonz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-19-2015 12:44 PM
SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout quiet-k Brakes, Suspension, Chassis 8 03-22-2014 10:17 PM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 04:40 AM
