Old 02-18-2015, 11:18 AM   #1
theGonz
theGonz's Avatar
Rear lower control arm dim
Can someone please give me the dimension of X in the following picture.
I prefer the dim from an OEM arm.
Thank you.
IG: theGonz
theGonz is offline   Reply With Quote
Old 02-18-2015, 06:10 PM   #2
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
41.75mm or 1.645"
I can get a picture with some calipers if you would like. This dimension is directly from the OEM control arms off of our car, if I had to guess they probably have a tolerance from factory of +/- 0.5mm or about 0.02"
Jeff@Racer X Fab is offline   Reply With Quote
Old 02-18-2015, 08:14 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
What is dim? Well other than the opposite of bright.
Old 02-18-2015, 08:17 PM   #4
Gunman
Drives: 2019 Mazda Miata RF
DIMension.
Gunman is offline   Reply With Quote
Old 02-18-2015, 08:25 PM   #5
Jeff@Racer X Fab
Made me laugh.
Old 02-19-2015, 12:44 PM   #6
theGonz
theGonz's Avatar
Originally Posted by racerx1715 View Post
41.75mm or 1.645"
Exactly, what I needed. Thank you, I have an aftermarket set where the collars were machined incorrectly, needed to know what nominal is.
IG: theGonz
FS: OEM Rear Lower Control Arm MicheleAbbate Brakes, Suspension, Chassis 23 12-31-2018 03:48 PM
SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout quiet-k Brakes, Suspension, Chassis 8 03-22-2014 10:17 PM
FS: SPC Rear Lower Control Arm used SoCal RiskyTrousers Brakes, Suspension, Chassis 0 03-14-2014 11:11 PM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 04:40 AM
Hancha Rear Lower Control Arm Hancha Group Suspension | Chassis | Brakes -- Sponsored by 949 Racing 62 09-21-2013 10:47 AM
