Old 11-03-2019, 04:26 PM   #1
solidsnake11
Drives: brz
New antilag flames and pops
C
solidsnake11 is offline   Reply With Quote
Old 11-03-2019, 04:31 PM   #2
gt7877
Drives: turbo frs
Steve any comments on the way of this mode
gt7877 is offline   Reply With Quote
Old 11-03-2019, 08:16 PM   #3
steve99
I think there is a minivum ignition timing tavle i think minium is set to -20 from memory
If you jave ecutek you could probavly do this without disavling the IAT
You could use custom maps only active when launch control active
Might not work as well NA as you wont have fhe turbo pushing air fuel mix through engine
solidsnake11 (11-03-2019)
Old 11-04-2019, 03:13 AM   #4
tomm.brz
Drives: brz 2017 hksv2
There is also a table called minimum ignition advance during FFS, it helps lower values specially when coolant is at temperature
Old 11-04-2019, 08:06 AM   #5
tomm.brz
ops.. no, sorry
not defined in Romraider defs, only in ecutek even if it s an OEM table and not a racerom table
you can try anyway to put more retard, like -50 or -55
Old 11-04-2019, 05:10 PM   #6
steve99
Their is a minium timng table in romraider defs its set to -20 for all rpm try changing that in rpm range required
Old 11-04-2019, 06:06 PM   #7
steve99
Ok its likely a hard limit in ecu coding then
Old 11-05-2019, 02:20 AM   #8
steve99
Originally Posted by solidsnake11 View Post
How is this table used?Attachment 182489
I believe that the amount of ignition timing subtracted when clutch is depressed.
Table view then properties somtimes has description
Old 11-09-2019, 11:19 PM   #9
HaXx
Drives: jrsc_brz
for flames you need no cats, but resonators wont dampen flames fight? im FI w/ catback, and im considering heads/over/front pipe/retune. catless but resonated. i simply cant be TOO loud so im thinking resonators, but no cats.
HaXx is offline   Reply With Quote
Old 11-10-2019, 12:29 AM   #10
tomm.brz
I figured this by injector flow at diiferent pressures and came up with percentages but it seems this table is not based on percentages because it threw my maf scaling way off.
it doesnt make a lot of sense what you did, you should increase more linearly
like that:
Old 01-10-2020, 06:08 PM   #11
zakman16
zakman16's Avatar
Drives: Man
Send a message via AIM to zakman16 Send a message via Yahoo to zakman16
hey guys i have a 2013 brz and i have and aftermarket catless header an invidia catless mid pipe and over pipe and an invidia n1 cat back and have an oft with a backfire tune and ive tried -7 all the way to -12 on my b timing and i still only get a popcorn backfire and occasionally a small flame here and there does anyone know why or how to change that because everyone that ive seen online has the same tune and is able to shoot decent sized flames out the back at like 4k rpm? is there a way to tune my car a little more rich to make the flames bigger?
zakman16 is offline   Reply With Quote
antilag solidsnake11 Software Tuning 1 10-24-2019 08:13 PM
Yellow FRS shooting massive flames! chazmuska Arizona 8 01-16-2018 02:46 AM
I want to shoot flames from my exhaust. EZWood Engine, Exhaust, Transmission 77 08-28-2015 04:27 PM
Liberty Walk Aventador shooting flames! Teeeg28 Off-Topic Lounge [WARNING: NO POLITICS] 0 11-01-2014 07:50 PM
D3 Performance Engineering RaceRom - Antilag/Boost Cut/Advanced BC/Trac ANTI_LAG Forced Induction 22 08-01-2013 10:15 AM
