Old 11-03-2019, 01:36 AM   #1
neroman98
Drives: 2014 Scion FRS Track Build
Manual Fan Override Switch
Hello everyone. I wanted to see if anyone knows how to wire a switch that turns on the fans even when the car is off. Basically I’m looking to do this because my car is a track build and I want to be able to leave the fans on to cool off the engine after sessions. Thanks!
neroman98 is offline   Reply With Quote
Old 11-03-2019, 08:57 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i believe most people connect a switch to some wires
there's been some rumors about wireless switches lately, but i think they're just blowing smoke.
Old 11-03-2019, 01:29 PM   #3
neroman98
Yes, but which wires do you connect the wires to? Do you run the switch straight to the fans? Do you connect it to some wires running to the A/C controls?
Old 11-03-2019, 01:53 PM   #4
soundman98
soundman98's Avatar
per here, starting at page 338:
http://www.ft86club.com/files/BRZwiringi.pdf
both trigger wires(positive and negative) off the relay go into different magic black boxes
*my initial impression is that the system is switched negative, with a ign-controlled feed, but the black boxes don't allow me to confirm that easily. if that were true, you would require both a constant power into the relay trigger, as well as adding wire to switch the ground leading away from the relay.
so i would suggest running an external relay and switch setup directly off the battery-- my initial impression/assumption of the existing system operation would require 50% of that work anyways.
Old 11-04-2019, 08:55 AM   #5
ka-titties
Drives: 2013 BRZ Limited 6MT
https://www.geraldjustprojects.com/p...gt86-trac-box/
Maybe?
ka-titties is offline   Reply With Quote
Old 11-04-2019, 10:20 AM   #6
neroman98
Originally Posted by ka-titties View Post
THATS PERFECT! I just ordered the Series Blue Panel Insert which is how I intended to set up my Fan Manual Override switch. Thank you!
diy, fans, interior, switch, wiring
Permanent Traction Override Switch DarrenDriven DIY (Do-It-Yourself) Guides 197 07-14-2020 11:03 AM
Manual fan switch drz400dude Engine, Exhaust, Transmission 7 01-15-2018 11:54 AM
Switch my auto for a manual or an s2000 or similar car orangespark Other Vehicles & General Automotive Discussions 21 05-24-2016 12:41 PM
Black door handles and shift bezel switch ( manual trans ) RacerDrews Interior Parts (Incl. Lighting) 5 06-14-2014 10:10 AM
Keep Auto Transmission or Switch to Manual Stayreal Engine, Exhaust, Transmission 41 03-23-2014 10:02 AM
