Old 01-06-2018, 08:01 PM   #1
drz400dude
Manual fan switch
Is there any way to wire up a switch for the fan? My coolant doesn't get hot, but my oil heats up going around town. I have an oil cooler, so I was wondering if there was a way to wire it to a switch and turn it on manually to draw air across the oil cooler when the fan wouldn't normally be on. Ideally, it would be a 2 position switch, on and auto(normal operation).
Any ideas?
Sent from my SAMSUNG-SM-N920A using Tapatalk
drz400dude is offline   Reply With Quote
Old 01-06-2018, 10:17 PM   #2
Northern_18
Drives: Silver 2016 Scion FR-S
What oil temperatures are you seeing? I don't think you'd see any dangerous oil temps if the coolant isn't triggering the rad fan to start especially if you have an oil cooler.
However, if you have a OFT you could change the values for the temperature that the fan will turn on at.
If you turn on the AC it would also turn on the 2nd rad fan to get air through the condenser.
Northern_18 is offline   Reply With Quote
Old 01-06-2018, 10:18 PM   #3
humfrz
Any ideas?
I'll betcha ol @Ultramaroon has some ideas ....... I'll summon him .....
Just how "hot" does your oil get ...... driving around town .....??
humfrz
Old 01-06-2018, 10:47 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
I turn on my AC and if it's cold out, adjust my heat accordingly.
Works great as long as the oil cooler is mounted in the path of side of the running fan. IIRC when the AC compressor is engaged, only one fan is triggered.
edit: Yeah, what @Northern_18 said.
Old 01-07-2018, 01:59 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You can, simple relay, wires and a switch.
But..... just what makes you think your oil gets way too hot in normal driving around town?
I and countless other owners that don't have an oil cooler have never had any high oil temp problems. (Unless your at the track pushing it hard, on a hot summer day.)
Old 01-14-2018, 12:59 PM   #6
drz400dude
In the summer when it is 110 out they are creeping close to 230...240F. I have a turbo, probably should have mentioned that in the first place. Under the hood gets super hot. I just wanted fresh air circulating when going around town. I didn't know the AC turned on the fan, makes sense. Maybe that will be enough to draw air across the oil cooler. Thanks!
Old 01-14-2018, 02:02 PM   #7
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
The 1st fan comes on at 200 degrees water temp, the 2nd fan comes on when your turn on the AC.
I had the same problem living near Palm Springs. I mounted my oil cooler outboard behind where the running lights had been. No it gets it's own cool air and less restriction for air going through the intercooler and radiator. I also put a small fan on the oil cooler with a switch. Works really great for slow city driving.
Lunatic is offline   Reply With Quote
Old 01-15-2018, 11:54 AM   #8
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
Plug and play, Beastronix 86Nanny will do this.
endless_pain is offline   Reply With Quote
Switch my auto for a manual or an s2000 or similar car orangespark Other Vehicles & General Automotive Discussions 21 05-24-2016 12:41 PM
FS: Unichip, USB cable, 2 tune selector switch, Clutch switch BII302 Engine, Exhaust, Bolt-Ons 6 04-13-2015 07:06 PM
Black door handles and shift bezel switch ( manual trans ) RacerDrews Interior Parts (Incl. Lighting) 5 06-14-2014 10:10 AM
Keep Auto Transmission or Switch to Manual Stayreal Engine, Exhaust, Transmission 41 03-23-2014 10:02 AM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
