Old 11-02-2019, 05:49 AM   #1
BrQ
Drives: 13 BRZ
UEL header for existing SBD turbo?
Might be a really stupid question, but how would one go about swapping the EL header on the SBD turbo, for a UEL option? Basically; I'm wondering if just buying an existing UEL turbo header would fit just fine, or if there'd be other things to consider?
BrQ is offline   Reply With Quote
Old 11-02-2019, 06:51 AM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
I've been thinking about this myself as well. But because I dont have SBD it would just make sense buying JDL. As much as people say is cheap it's not.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 11-02-2019, 07:28 AM   #3
Lantanafrs2
Drives: 2013 frs red
Uel turbo header? Why?
Old 11-02-2019, 08:31 AM   #4
BrQ
Drives: 13 BRZ
SBD turbo is excellent. Have had it for over a year with absolutely zero issues and the BOV is still intoxicating to hear.
Old 11-02-2019, 08:39 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It can be done, but you'll be re-doing the intercooler piping, possibly all oil drain and feed lines, probably the coolant lines, your downpipe from the turbo to meet the exhaust. UEL will offset the turbo positioning. Why not sell it and go JDL? You'd lose a lot less money doing that and get a worthwhile turbo. You'll also be hard pressed to find a UEL header with a T25 flange and no external wastegate flange. Pretty sure it's T25 and not T3 anyway....
DarkPira7e is online now   Reply With Quote
The Following User Says Thank You to DarkPira7e For This Useful Post:
BrQ (11-02-2019)
Old 11-02-2019, 09:41 AM   #6
BrQ
Drives: 13 BRZ
This is what I needed to know, thank you. Wasn't sure how different they were between the two. This is the first car I've worked on.
Will be sticking with the sbd as it's perfect as-is, just wanted a different sound. Will be going the catback route instead.
Old 11-02-2019, 10:26 AM   #7
Lantanafrs2
^ good idea. If the car is dialed in and fast, enjoy it. Lots of money goes down the toilet trying to reinvent the wheel
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
sroby (11-04-2019)
Old 11-02-2019, 10:39 AM   #8
DarkPira7e
DarkPira7e's Avatar
It's an incredible bargain for the performance. Just be sure to get a really good tune and it'll last! Try to avoid low RPM high load conditions like flooring it at 2,500 RPM. Yes, you can build boost, but this is what breaks rods!
sroby (11-04-2019)
Old 11-03-2019, 02:43 PM   #9
BrQ
Drives: 13 BRZ
Absolutely, already know which catback I'm going for. Would love to just go for a hood exit exhaust but I'm not trying to wake my neighbors.
Old 11-07-2019, 08:54 AM   #10
Fred E
Drives: WRB BRZ
JDL sells a drop in replacement UEL manifold for "popular t2/t25 based turbo kits" (read: SBD). This is a designed as a direct swap/upgrade. They do not list this on their website, so you will need to contact them to order.
Fred E is offline   Reply With Quote
The Following User Says Thank You to Fred E For This Useful Post:
BrQ (11-21-2019)
Old 11-07-2019, 08:57 AM   #11
Joveen
Joveen's Avatar
Drives: Bone stock
Wow never knew that.
Existing kits and how they fit on the 2017s Xork Forced Induction 0 05-15-2017 12:34 AM
Looking for help adding sub and amp to existing 2016 FRS sound system and head unit Sonicp9 Electronics | Audio | NAV | Infotainment 2 02-27-2016 10:24 PM
Time for new plates. How to look up existing customs? stockysnail Northwest 2 05-20-2014 11:44 AM
Would FB Green or Red fit any existing kit? HighLife Forced Induction 17 01-04-2013 05:18 PM
Future and Existing Toyota/Scion/ TRD Parts List Tanuki Scion FR-S / Toyota 86 GT86 General Forum 1 10-04-2012 10:59 AM
