Old 10-02-2019, 02:49 AM   #1
iceblaze
Drives: 2014 Scion FRS MT,2017 Toyota 86 AT
Tach and mph clusters are way off
Ended up being an easy fix
iceblaze is offline   Reply With Quote
Old 10-02-2019, 10:35 AM   #2
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Maybe the previous owner replaced the cluster for some reason....I don't know if you can program mileage into these clusters, but if not, they may have tried to replace the cluster with one that shows a lower mileage than the original did.
I think the dealer should be able to reset it for you so all the gauges properly zero and properly read.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 10-02-2019, 01:16 PM   #3
Overdrive
Sittin' Sideways
Overdrive's Avatar
I think they should be able to. Sometimes gauges do get out of sync since they're not all physically tied to something like they used to be. I'm pretty sure the dealer has the ability to recalibrate them all should that happen. If it happens again then you might need to look into why that cluster was messed with, and/or make sure they didn't pinch or fray any of the wires involved. Electrical shorts make gauges do funky things.
-O/D
2016 FR-S, Hot Lava
Is there a difference between gauge clusters UDSM brz vs EU/AU brz? wutangbrz BRZ First-Gen (2012+) — General Topics 1 01-24-2019 06:21 AM
DashCommand PRO Clusters MY13&MY17 NEW! Trap63 DIY (Do-It-Yourself) Guides 2 09-02-2016 03:34 PM
Modded Gauge Clusters CThomas Cosmetic Modification (Interior/Exterior/Lighting) 2 03-21-2015 08:45 PM
BRZ tach to FRS? lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-01-2013 03:48 PM
