Old 09-30-2019, 07:12 PM   #1
CoolHandMoss
Drives: 2013 FRS
FS: HKS camber plates. $120 shipped
SOLD
Edit: HKS should be HVT. These are HVT camber plates. I had a brain fart and no cannot edit the title.
These are pretty old. They have probably been in use since 2012. They definitely show plenty of wear but hey still function just fine. The only functional drawback is that the slots where the clamping screws ride are a little roughed up so you have to back the screws out a turn or two in order to be able to move the spherical carrier thing smoothly to adjust camber. I would still be using these if not for getting new camber plates that allow caster adjustment. These are great for maximizing compression travel by raising the mounting point of the damper shaft in relation to the body. All included hardware is pictured. Nothing that is not shown in the following pictures is included. I'm selling these cheap because they do show so much wear but these are quite well liked parts and no longer available. $120 shipped to the lower 48 states. Paypal preferred. PM if interested rather than responding in this thread so I get a notification.
upload a photo online
CoolHandMoss is offline   Reply With Quote
Old 09-30-2019, 09:38 PM   #2
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Are these a direct replacement for the stock suspension tophats or do I need additional parts?
gcranston is offline   Reply With Quote
Old 09-30-2019, 09:50 PM   #3
CoolHandMoss
Drives: 2013 FRS
I am honestly not sure. I 'believe' they will work with stock struts but I leave it to you to verify that for yourself.
Old 09-30-2019, 11:03 PM   #4
gcranston
What shocks were you running them with?
Old 10-01-2019, 06:17 AM   #5
CoolHandMoss
Drives: 2013 FRS
I have used the with KW's and MCS both.
Old 10-01-2019, 10:33 AM   #6
CoolHandMoss
Drives: 2013 FRS
If a moderator could edit the title to show HVT instead of HKS I would appreciate that.
Old 10-03-2019, 08:28 AM   #7
CoolHandMoss
Drives: 2013 FRS
SOLD
Uneven camber with the camber plates maxed. fr-steezz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 09-27-2022 09:15 AM
SOLD: Raceseng caster + camber - adjustable front camber plates higrip Brakes, Suspension, Chassis 4 09-17-2019 01:43 PM
FS: HVT Non-raising camber plates & WL camber bolts trippinbillies40 Brakes, Suspension, Chassis 1 05-16-2015 09:00 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
