Old 09-28-2019, 07:58 PM   #1
juniorrr
Drives: Scion Frs
How do I test if an end link is bad?
I’m still trying to diagnose the reason why my car squeaks turning leff while in motion and I suspect it’s a bad endlink but I’m not 100% sure so I was wondering anyone here knows how I would be able to test if my endlink has gone bad or not? Thanks!
juniorrr is offline   Reply With Quote
Old 09-28-2019, 08:03 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
Having the same issue.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 09-28-2019, 08:20 PM   #3
juniorrr
Drives: Scion Frs
Someone told me to just remove the end links and drive around really quick and see if the noise goes away, and if it does then it’s the endlink but idk how safe that is?
Old 09-28-2019, 08:27 PM   #4
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
cars handling doesnt go to shit when you remove endlinks/sway bars
they jsut a little looser and youll feel the body roll more. if hes just disconnecting it and shooting up the block and back? easy day
off road guys typically dont run endlinks or sways
Clutch Dog is offline   Reply With Quote
Old 09-28-2019, 08:52 PM   #5
juniorrr
Drives: Scion Frs
Okay cool thank you. so if I’m disconnecting one of them should I just disconnect both or the one that I suspect is bad only?
Old 09-28-2019, 08:58 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Disconnect both. Be sure to ziptie the swaybar in place while they're off
Compression test numbers? Anyone done running comp test? Crunk81us Engine, Exhaust, Transmission 2 11-10-2017 01:35 PM
Hey guys I recently test drove the 86 straight after test driving the Megane RS. Obsessionz Scion FR-S / Toyota 86 GT86 General Forum 32 09-23-2014 01:20 PM
Rear toe link and toe changes Suberman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-30-2014 06:49 AM
P&L Header Dyno and Fitment test-With my Vortech Test Kit Huehuecoyotl Engine, Exhaust, Transmission 118 07-07-2013 10:26 PM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-01-2012 11:45 PM
