Old 09-21-2019, 05:16 PM   #1
imhereforthecar
Drives: FRS
Wheel Speed Sensor A P0500
Got this error code. Does anyone know the location of speed sensor 'A?'
imhereforthecar is offline   Reply With Quote
Old 09-22-2019, 04:22 AM   #2
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
IIRC, P0500 is a generic ECM code for a circuit fault within the entire wheel speed sensor system. It is set by the ECM when another module has detected a fault in the vehicle stability and speed sensors network (e.g. ABS, TCM if you have an AT car, etc.). This car has around 14 modules that each set their own codes; if your scanner doesn't read them all, you'll need to find a bi-directional scanner that does.
Once you scan the ABS module, it should point you to the specific sensor and circuit component(s) that aren't reading properly. If the ECM is reporting "A" correctly from the ABS module, I would imagine it is referring to "circuit A," not a particular sensor; however, I don't know for sure.
theadmiral976 is offline   Reply With Quote
Old 09-22-2019, 11:09 AM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
"Speed sensor A" exists only as a numerical value in memory.
It's the speed of the vehicle, derived from all 4 wheel speed sensors as seen by the Stability Control ECU, cleaned up, put in a neat little package and sent over the network to the Engine Control Module.
Admiral is on point, you need a scan tool that can go read DTC and live data from the stability control to know what's actually wrong.
CEL P0500 Vehicle Speed Sensor Malfunction travisb Issues | Warranty | Recalls / TSB 34 06-23-2021 04:12 PM
Wheel Speed Sensor Tire size drama Celigts Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-03-2019 03:08 PM
P0500, speed sensor issue, weird case. darkbluemn Issues | Warranty | Recalls / TSB 5 01-14-2018 01:31 PM
So i broke my wheel speed sensor bkblitzed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 11-18-2016 05:04 PM
P0500 after wheel stud install theman233 Issues | Warranty | Recalls / TSB 3 05-21-2016 10:50 PM
