Old 09-20-2019, 09:21 PM   #1
Dububster
Dububster's Avatar
Traction control problem
Hey guys! I’ve had my 2013 BRZ for a month now and I’ve been noticing that my stability control has been turning on when I take corners a little hard(at a speed it should be able to handle). Isn’t traction control only really supposed to come on in the rain and if you really are about to loose control? My car is completely stock. I also took my car to the shop and they said they couldn’t find any problems. Let me know if I’m missing something here and thanks for the help!
Dububster is offline   Reply With Quote
Old 09-20-2019, 09:23 PM   #2
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
Sounds normal. And it is the stability control you are experiencing.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
Old 09-20-2019, 09:55 PM   #3
Dububster
Dububster's Avatar
Does it do the same thing with you?
Old 09-20-2019, 10:44 PM   #4
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
yes, the stability control keeps the car in check if it senses something out of its parameters between wheel speed and rpm and slidea angle and yada yada
hit the sport button to lift those parameters a bit higher
I turn it all 'off" for open tracking, but it keeps them active just raises the limits even higher, youd need a beastronix or oft to activate "pedal dance " mode but honestly outside of autox youd never really need it. I did a few laps at buttonwillow between just holding the traction control off vs pedal dance and i iwas faster with the traction control held off
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
new2subaru (09-20-2019)
Old 09-20-2019, 10:53 PM   #5
new2subaru
Weight Weenie
Drives: 15 FR-S
It’s normal. Sounds like crap, eh?
I used to turn mine off all the time but now only do it on track. I’m not sliding anywhere with stickier tires. I should put the stockers back on for a while
ETA There’s no track button in a 2013. Just they traction control buttons which can be turned off if desired.
Old 09-20-2019, 10:55 PM   #6
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
TCS and VSC work to limit the tire slip. You don't have to be drifting or hydroplaning to experience tire slip. If the vehicle detects that tire is slipping, it will apply brakes to counteract the slip. The TCS is going to operate with the goal of limiting tire slip well before you lose control, not just before....in most cases it would be too late by then. It is every bit a preventative system as it is a reactive one.
The TCS/VSC in the 86 is much to intrusive for my taste. First thing I do when I start the car is put it in VSC sport.
BlueWhelan is offline   Reply With Quote
Old 09-20-2019, 11:01 PM   #7
Dububster
Dububster's Avatar
Ok, I appreciate all the info everyone it helped a lot!
Old 09-21-2019, 08:54 AM   #8
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
It's literally impossible to say if it's normal with just "when I take corners a little hard".
My stability control doesn't kick in when taking corners "a little hard", my dash cam at the least sensitive setting thinks I've crashed ages before stability control would think to cut in. But stability control intervention has a lot to do with the driver and what you are doing in those corners. I often tell people the story of my old 4Runner that I would drive around pretty hard and even drifted through a few off ramps. I'd often give rides to my sister so she got used to "my speed". One time she drove it and was unconsciously going "my speed" and she was lucky to not flip it, she had it on two wheels and eventually off of the street over the sidewalk. Same corner, same speed, different driver inputs, different stability.
Stability control will kick in when the yaw rate sensor detects slip angle amongst other things. How granular is your throttle control? How delicate are you with the wheel? Is the threshold for slip unexpectedly low thanks to slippery tires or a bad alignment? Are you going just that fast?
Can't tell over a few lines of text.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
soundman98 (09-21-2019), Tcoat (09-21-2019)
Old 09-21-2019, 09:49 AM   #9
Let's not forget the technical aspects. Are your tires all the same front and back and side to side? What sort of condition are the rears in?
Old 09-21-2019, 10:16 AM   #10
soundman98
ProCrastinationConsultant
soundman98's Avatar
And what pressure are they at?
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
DarkPira7e (09-21-2019), Tcoat (09-21-2019)
Old 09-24-2019, 02:40 PM   #11
Dububster
Dububster's Avatar
By saying stability control turns on easily I mean that I haven’t had any tire squeal because it turns on before I get any. The tire pressure is all good. I have the tires on that I bought it with, Michelin pilot sports in the front that are a bit worn down but not to the point that they need to be replaced yet. On the back I have new Yokohama Avid EnVigor tires on.
Old 09-24-2019, 02:59 PM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
There is your problem. Different tires front and rear will cause this issue. I had the Exact same thing happen when I had Michelin Pilot Sport tires on the front and All seasons on the rear.
I LIKE TIRES!
soundman98 (09-24-2019)
Old 09-24-2019, 04:53 PM   #13
Dububster
Dububster's Avatar
Ok thank you so much for the help, I’ll look into getting new tires.
The Following User Says Thank You to Dububster For This Useful Post:
Leonardo (09-24-2019)
Old 09-30-2019, 12:22 PM   #14
Mykii
Noodleking
Mykii's Avatar
Drives: 2013 Firestorm FRS
Yeah, I had one tire replaced due to a nail, and it caused my traction control to freak out.
Traction control was getting super sketchy. It would randomly kick in on the freeway at 65 around a long left turn. it was super trippy. I guess the diameter of the new tire much more than the other worn down tires. I had to purchase another to sort of even it out.
The passenger rear tire was the first one to get replaced, followed by the driver's rear. When both new tires were in the rear (thanks Discount tire, you dorks), my car would try to push the front end and traction control would kick in. I then rotated my tires, and it's been smooth after that.
Mykii is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
Traction controll problem after steeing wheel install... NickGTI32 Issues | Warranty | Recalls / TSB 9 10-01-2014 04:09 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 01:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 04:28 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
