Old 09-20-2019, 01:29 AM   #1
juniorrr
Drives: Scion Frs
Help installing Overpipe
Hey guys so I’m about to install my Tomei Overpipe soon and I was just wondering if you guys could break down for me how to install it the proper way. If there’s a diy thread for this feel free to link. Thanks I appreciate it guys!
juniorrr is offline   Reply With Quote
Old 09-20-2019, 02:11 AM   #2
86MLR
86MLR's Avatar
Youtube it mate
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 09-20-2019, 02:58 AM   #3
Lantanafrs2
Drives: 2013 frs red
Big hammer. In all seriousness there are some YouTube videos detailing the installation.
Old 09-20-2019, 03:39 AM   #4
86MLR
86MLR's Avatar
Pull the engine mount bolts
Old 09-20-2019, 01:16 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Takes some serious tetris.
Need to remove heatshield from stock overpipe. Otherwise, you'll need to lift the engine a bit
EndlessAzure is online now   Reply With Quote
Old 09-20-2019, 04:38 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
You actually don't need to lift the engine. You can rotate the piping and finagle it over the subframe once you've taken the heat shielding off. Though taking the headers off or the front pipe off significantly helps. Otherwise, yeah you might need to jack the motor. As for the rest of the install, it's seriously unbolting something and then bolting it back in.
MS, CSCS, TSAC-F, CPT
Old 09-20-2019, 06:13 PM   #7
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
best way I was able to do this
jack car up.
secure with wheel chocks
find the engine mount bolts to lower subframe, loosen and back off but do not remove completely
take floor jack on a wide 2x6 and jack up on oil pan.
remove over pipe, and place into position new overpipe. let engine back down and tighten
move overpipe into position and tighten down.
thats how i did it easy day and no worries about the engine moving too much. the nut threaded on the bolt will prevent you from remving it too much
Clutch Dog is offline   Reply With Quote
Old 09-22-2019, 07:35 AM   #8
juniorrr
Drives: Scion Frs
jack car up.
Thanks guys for your inputs and may there’s two medthods so far I guess heat shield and and play around or just lifer it. I have a question if I left up the engine by the oilpan with a piece of wood, could this dmg the oil pan in anyway? I was worried it would and wanted to do it the other method but I’m not sure if it does or doesn’t let me know. I’m assuming lifting the engine is faster?
Old 09-22-2019, 02:04 PM   #9
Clutch Dog
Wide piece of wood on the oil pan. The oil pan is steel and you aren't hitting it with force. Just lifting it up a smidge. And it'll be fine.
Old 09-22-2019, 06:36 PM   #10
Hawk77FT
Drives: GTS 86
Use this tip: try doing it from the front of the car to the back. I have installed several of them with no issues whatsoever. If is one of those big fck off one, like 2.75 or 3", loosen the engine mounts bolts and lift the engine up a little. Use a piece of timber to lift it by the oil pan.
Good luck bro!
Hawk77FT is offline   Reply With Quote
WTB - 3" overpipe & Perrin 2.5" overpipe for sale DAN_BRZ Canada Classifieds 1 02-27-2015 01:15 PM
which is better the p&l overpipe or motiv overpipe Anthony7515 Engine, Exhaust, Transmission 15 04-08-2014 07:00 AM
Installing Overpipe Question TONY_BRZ Engine, Exhaust, Transmission 13 03-19-2014 12:46 AM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 01:17 PM
