Old 09-10-2019, 06:31 PM   #1
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
STI Motor Mounts
Used for about 2 months/2k miles. Worked great just needed something a little stiffer when I went boosted.
SOLD
MotoX16 is offline
Old 09-11-2019, 09:50 PM   #2
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
I'm very interested but can you work on the price? These are $259 brand new at subispeed
Ignore Your Doctor is offline
Old 09-15-2019, 05:36 PM   #3
MotoX16
MotoX16's Avatar
BUMP. Price reduced
MotoX16 is offline
Old 09-17-2019, 06:38 PM   #4
sroby
Drives: 2015 Firestorm 08/05/15
sroby is offline
Old 09-25-2019, 09:41 AM   #5
MotoX16
MotoX16's Avatar
bump
MotoX16 is offline
Old 09-29-2019, 04:11 PM   #6
Steveiam
Drives: 86
I'm going turbo soon so I was thinking of picking these up. Are these not stiff enough for FI setup?
Steveiam is offline
Old 09-30-2019, 12:42 AM   #7
Joveen
Joveen's Avatar
Drives: Bone stock
Coming from a car that from a car that does have a turbo why wouldn't it be? Also daily comfort. I'm going for the new perrin ones tho.
Sent from my SM-N960U using Tapatalk
Joveen is offline
Old 09-30-2019, 09:21 AM   #8
MotoX16
MotoX16's Avatar
Depends on your exhaust setup. I have the jdl 3" dual resonated op/fp combo. The clearance between the 3" pipe and the subframe is so small I needed stiffer mounts so it would stop rubbing under hard acceleration. I think if you had a 2.5" op you'd probably be fine
MotoX16 is offline
Old 09-30-2019, 07:51 PM   #9
Ignore Your Doctor
FYI this is a clearance issue not a motor mount issue. There are a number of threads with the same issue and most report that a few washers on the motor mounts fixed the issue.
Old 09-30-2019, 11:42 PM   #10
MotoX16
MotoX16's Avatar
Some washers may have helped. But I was running the same exhaust NA with the STI mounts and no issues. Regardless, once I switched to the Cusco mounts my motor is nice and stiff and the exhaust doesn't rub anymore
MotoX16 is offline
Old 07-06-2020, 11:44 AM   #11
MotoX16
MotoX16's Avatar
SOLD
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17
MotoX16 is offline
FS: STI Motor + Trans Mounts hello86 Transmission and Driveline 6 08-17-2017 12:23 PM
STI motor mounts AdrianG Canada Classifieds 2 10-23-2015 09:01 AM
FS: Perrin Motor Mounts F1point4 Engine, Exhaust, Bolt-Ons 4 01-18-2015 02:19 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
Lowest NVH motor mounts? OICU812 Engine, Exhaust, Transmission 41 12-03-2013 09:04 AM
