Old 09-09-2019, 11:16 PM   #1
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
STX Gurus lend me your eyes...
So I bought a modified car earlier this year. Some of the mods put me straight into CSP which has been my playground with no local competition. My e30 was in DSP before that with the same issue, and it's frustrating. I don't want to go to full street prepared prep, so I'd like to drop a few little mods to fit into the STX sandbox. Possibly give a go at nationals next year if I'm feeling frisky. Before going crazy it seems like I should get some fresh eyes on this.
Here's the mods I should be able to keep:
Whiteline Anti-Dive Caster kit
Raceseng Cascam Plates
Grimmspeed strut brace
Whiteline Adjustable end links
Eibach Anti-roll kit
KW V3 coilovers
SPC adjustable LCAs
Falken rt615k+ (for now)
Sparco Champion wheel
NRG Gen 2 quick release
NRG short hub
Forever Sharp horn button
Goodridge stainless lines
EBC Yellowstuff pads
DBA T3 rotors all around
Motul RBF600 brake fluid
Motul 300 Gear oil trans/diff fluid
OFT v1
Beastronix Speed Academy pedal dance box
Wheel studs
Iffy class stuff:
Grimmspeed master cylinder brace
From what I can tell the following put me out of class:
e85 tune
Hooker Blackheart catless front pipe + catless Tsudo UEL header/overpipe
Whiteline Roll Center / Bump Steer Kit (Ball Joints, Tie Rod Ends)
Whiteline Adjustable Toe Arms
Enkei NT03+M Wheels 18x9.5 +40MM (Black)
Velox Throttle Pedal Spacer Kit
Downforce Carbon Fiber Front Lip
Carsmo Design Rear Duckbill Trunk Spoiler
Perrin Steering Rack Lock + Whiteline Steering Rack & Pinion Mounts
Any thoughts or suggestions are much appreciated!
captain awesome is offline   Reply With Quote
Old 09-10-2019, 12:05 AM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
throttle pedal spacer kit should be allowed. it is a driver interface mod or "comfort and convenience" Hell I run a steering wheel spacer too
but yes the e85 tune and everything else would be non STX legal.
The master cylinder thing: " t was approved in August Fasttrack.
#22139 Master cylinder brace allowance in ST
The STAC and SEB recommend the following allowance for a bolt-on brake/clutch master cylinder brace mirroring the allowance present in the SP category. This is as a new line in section 14.6, as follows:
“G. A single brake master cylinder brace may be added provided it is bolt-on and serves no other purpose.”"
Clutch Dog is offline   Reply With Quote
Old 09-10-2019, 12:53 AM   #3
strat61caster
strat61caster's Avatar
For locals I think you've nailed it plus the above about the cylinder brace.
nitpicky nationals level problems:
SPC LCA's have a spherical bearing that's not legal, you can press in a replacement bushing (Diftech makes one) or swap to a different LCA
Sparco steering wheel should be weighted to match OE steering wheel weight (or just swapped back to OE)
If you're winning, it's not because your steering wheel is 5 lbs lighter or your rear lca can pivot a direction it never needs to pivot so I wouldn't rush to fix these unless you're headed to Nationals with the car.
ineedyourdiddly
Old 09-10-2019, 07:37 AM   #4
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
IMO, I'd switch it back to OEM. There is a rule about the airbag as well.
13.2 D. Alternate steering wheels are allowed, provided the outside diameter is not changed by more than one inch from the standard size. Steering wheels with an integral airbag may not be changed.
Now, if you were to find a wheel that kept the OEM airbag, that could work.
BigTuna is offline   Reply With Quote
Old 09-10-2019, 08:34 AM   #5
captain awesome
Wears Pants
Those are street class rules you listed, not street touring.
Here's the street touring rule:
14.2 D. Any steering wheel may be used. An alternate steering wheel assembly, including all mounting hardware which replaces an airbag-equipped wheel, is not required to have an airbag but must weigh at least as much as the standard assembly. An alternate steering wheel is not required to have a horn button.
The Following 2 Users Say Thank You to captain awesome For This Useful Post:
BigTuna (09-10-2019), strat61caster (09-10-2019)
Old 09-10-2019, 08:47 AM   #6
BigTuna
BigTuna's Avatar
You're right. My bad. I used Ctrl+F and it moved me back up to street and I didn't realize.
Old 09-10-2019, 08:48 AM   #7
captain awesome
Wears Pants
Nice to know about the M/C brace.
Old 09-10-2019, 08:52 AM   #8
captain awesome
Wears Pants
I'll look out for a different LCA or just swap bushings if things get serious.
As for the steering wheel, I think it's pretty close in weight when I factor in a heavy metal cruise control bracket, horn button, quick release stuff, and hub. One of these days I'll weigh it all to compare, but don't think it would require much effort to get them close enough.
The Following User Says Thank You to captain awesome For This Useful Post:
Old 09-10-2019, 09:27 AM   #9
captain awesome
Wears Pants
No worries. I've done it myself a couple times before.
Old 09-10-2019, 01:31 PM   #10
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Only thing I was going to ask you is did you check the weight on the steering wheel. Most aftermarket ones need ballast to be legal.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 09-10-2019, 01:47 PM   #11
captain awesome
Wears Pants
I'll have to see what I can find for ballast. I know locally I'm good, but for Mid-Div and Nationals I know it's going to be something to look into.
Old 09-11-2019, 03:34 PM   #12
captain awesome
Wears Pants
Last night I noticed the spoiler adhesive was already starting to pull away on the bottom side of the trunk lid. Next thing you know I've spent 15 minutes pulling and prying to get the thing free from the trunk lid. Once it was free my gut got a bit squirmy. This thing has been here a while. After some hasty cleanup, the paint doesn't match the rest of the trunk now, and there's enough blemishes/scratches that a re-spray would be the only option. I'm not a painter.
I panicked a bit. A lot really.
Some cleaning and scraping took the old adhesive stuff off. My fingers are now heavily blistered. What a genius idea this has been. I stared at it for a few minutes minus the spoiler, and then proceeded to stick it back in place with new 3m trim tape. Not a fan of the looks, but mainly because it's going to cost some money to get the trunk lid back to purty status. Maybe STX is for the birds?
I'll start looking for a whiteout trunk to swap or buy before too long. Not the outcome I was hoping for, but at least I know now.
Untitled by hatchethairy, on Flickr
Anyone free to lend a hand KungFuWaffle Southern California 5 10-08-2016 01:15 PM
Anyone lend a hand? Sheepdog Arizona 0 08-01-2015 06:22 AM
can anyone lend me one oem wheel + oem tire? 7thgear CANADA 1 05-02-2014 11:48 AM
Anyone local to South OC willing to lend me stockers? eddieEndo Southern California 1 02-05-2014 03:10 PM
Can anyone lend me a helmet for a track event Fri? mistressmotorsports Southern California 8 11-13-2013 02:51 PM
