Old 09-06-2019, 11:43 AM   #1
Cookiemonster
Cookiemonster's Avatar
Drives: '17 BRZ M6 & '17 Corvette Z06 M7
18" Work Emotion T5R - 2PC?
After doing some unsuccessful searching in this section of the forum, I have to ask - is anyone running 18x9.5 or 18x10 Work Emotion T5Rs (2pc version)?
I know you'd need the 5x100 -> 5x114.3 conversion to run them, but they're the only 2 pc 5 spoke design I've seen that I'm really loving.
Just wanted to see if anyone here is running them and if so, tire specs you're running as well as any clearance issues around the 17+ sport package brembos.
Thanks!
Cookiemonster is offline   Reply With Quote
Old 09-19-2019, 05:08 PM   #2
Cookiemonster
Well, then...guess not : (
Old 09-19-2019, 06:23 PM   #3
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
DM System Motorsports on IG, they have those Works and the owner is knowledgeable on FRS/BRZ fitment. I'd probably run 255/35 if I was you
Shizuka is offline   Reply With Quote
Old 09-19-2019, 06:33 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
This thread has work wheels sized 18x10. They are a different wheel. Not that many guys run a 18x10, so there are not alot of pics. On the other hand, 18x9.5 wheels are VERY common - tons of pics and info on how to make them fit.
18x10 thread
http://www.ft86club.com/forums/showthread.php?t=38778
info on the 5x114.3 conversion and how to retain OEM brakes
https://www.ft86club.com/forums/showthread.php?t=129799
I LIKE TIRES!
Old 09-24-2019, 08:56 PM   #5
Cookiemonster
Thanks for responses guys. After looking into wheel fitment and cost some more, I don't think I'm going to run these in 18x10 form after all.
I'm going to go widebody down the road, so I think I'm just going to look at putting some super sticky tires on the stock wheels for now or buying a cheap pair of used 18x9.5's that I'll run with til I get the widebody kit. I'm planning an engine swap, so I'll need as much grip as I can get, but am budgeting the widebody kit later on simply due to budget constraints.
2pc, emotion, t5r, work
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 kimchangil424 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 01-03-2017 06:00 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
FS: WORK Emotion CR Ultimate "Kiwami" 18x9.5 +38 Matte Bronze Audeze Wheels and Tires 8 03-19-2015 05:30 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 02-25-2014 06:00 AM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 JDMenrique Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 08-25-2013 01:48 PM
