Drives: 2013 FRS
Coolant leak, radiator replacement
So my car has been leaking coolant and I'm 95% sure it's coming from the radiator. Assuming that's the case, I'm trying to figure out if I should just get another OEM radiator ($330) or an aftermarket one.
I have a JDL turbo kit and even with the leak, my coolant is ~198 degrees at operating temp, so I'm not too worried about needing more cooling, and thus I'm inclined to replace it with an OEM radiator. I have seen some cheaper aftermarket options which I'd be hesitant to buy, but would consider if others have good enough things to say about them. I'd also like to switch out the fan shroud regardless to make more space, as the OEM shroud is extremely close to the turbo. I was thinking of the JDL fan shroud. Opinions on this would be appreciated as well. Thanks! |
Drives: 2017 toyota 86
Im using mishimoto radiator and fanshroud, no complaints or issues. Never seen temps hit 200F hooning around with a sprintex SC and forester oil cooler which generally raises coolant temps when oil temps get higher. Even 230F oil, coolant is still steady at 195F.
Mishimoto is advertised at 46% more cooling capacity and is 290$ , so cheaper than a new OEM radiator. But if you want OEM PM me an offer i got one pulled off my 2017 at 2k miles ill sell you. Last edited by 86TOYO2k17; 09-04-2019 at 09:13 PM. |
Rust bucket enthusiast
If your OEM radiator is doing well enough, I don't see a big rush to upgrade. Why not get the radiator pressure tested to be sure that's where the leak is?
On the other hand, upgrading is nice sometimes... I'd stay OEM as long as possible though |
Weight Weenie
Drives: 15 FR-S
If you posted a wanted ad on here you might get one cheap. There’s no real reason to not go OEM
Bubba says to put a can of "stop leak" in it. -
![]() humfrz |
Drives: 2014 BRZ
I'd stay OEM. I have the JDL shroud, and have plenty of clearance. With a pair of 909 cfm SPALs, OEM rad, and OEM water/oil cooler and roughly 70 water/30 coolant mix my coolant is always right around 190 and sometimes hovers close to 200 for brief periods. Oil usually around 215 with spikes to 230ish, Florida street driving.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Where you located?
2013 Series 10 FRS #553
| Coolant temps with Jackson radiator? | dstrout | Engine, Exhaust, Transmission | 1 | 07-11-2018 03:26 PM |
| Possible coolant leak | RedNWhite | Issues | Warranty | Recalls / TSB | 19 | 09-25-2016 09:35 PM |
| Dots in coolant(open radiator cap) | Tank42 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 01-26-2016 10:52 PM |
| Radiator Leak? | Cal3000 | Engine, Exhaust, Transmission | 3 | 10-13-2015 04:57 AM |
| coolant leak or burned rubber smell | Saf | Issues | Warranty | Recalls / TSB | 7 | 02-27-2014 01:33 AM |
