Drives: 16' BRZ
High temp diff gaskets?
Does such a thing exist? I’m loosing diff fluid and am wondering if there are better replacement gaskets than oem?
Drives: 2017 toyota 86
Its Red RTV no gasket, just redo it. But are you sure its leaking from there and not from a bad axle seal? Did you recently pull out the axles?
Drives: 16' BRZ
Thanks for the reply! Yes, you are correct it is the axle seals. They are DSS 600hp axles. Do you have any advice? On a side note I was able to find a high temp diff gasket online and I’ll give it a try.
Possibly nicked the seal on install, or the garter spring popped off. Either way new seals should do the trick, just make sure to grease the axle tip and the seal when installing to make sure it doesn't get damages.
No need for gaskets. You need to replace the seals.
Confirm that your DSS axles do in fact require the stock seals and not something else. |
| Diff and Transmission Gaskets/Crush washers | Lakitu | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 06-11-2018 11:59 PM |
| High coolant temp at idle with A/C off | extrashaky | Issues | Warranty | Recalls / TSB | 11 | 11-11-2014 04:50 PM |
| p0198 code oil temp sensor malfunction circuit high | kingkai23 | Forced Induction | 10 | 06-17-2014 01:22 PM |
| Where to order trans/diff gaskets? | ZionsWrath | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 11-11-2013 01:46 PM |
| Volunteers to help install my high temp brake fluid and pads with me? | stockysnail | Northwest | 9 | 07-22-2013 05:15 PM |
