Old 08-31-2019, 02:49 PM   #1
mrg666
pessimistic skeptic
mrg666's Avatar
MMT octane boosters
Is there any experience using MMT octane boosters? I am going to try one of them, wanted to know if there is any experience
Old 09-01-2019, 02:04 AM   #2
solidsnake11
Drives: brz
https://www.fuelexpert.co.za/Octane-...r-Shootout.php
I used toluene in my old beater 86 Toyota, 7m pickup 1/4 mile was 11.35 @ 125mph
solidsnake11 is offline   Reply With Quote
Old 09-01-2019, 04:22 AM   #3
tomm.brz
Drives: brz 2017 hksv2
just buy BSF bardhal if you want to use an octane booster, it works
Old 09-01-2019, 09:43 AM   #4
86TOYO2k17
Drives: 2017 toyota 86
Boostane, i tested it on numerous tunes, was able to get more timing and more steady IAM with even only 1/3rd bottle. Torco was the standard, boostane stepped it up a notch.
Lots of dyno testing as well.
https://www.enginelabs.com/engine-te...-adds-24-rwhp/
https://www.gtrlife.com/forums/topic...ctane-booster/
https://thetuningschool.com/blogs/ne...chnical-review
https://boostane.com/category/dyno-r...ing-race-fuel/
Old 09-01-2019, 09:48 AM   #5
86TOYO2k17
That study's 20 years old. Lots of advancements since.
Old 09-01-2019, 10:14 AM   #6
solidsnake11
Drives: brz
So is a 2jz! lol.
Old 09-01-2019, 10:31 AM   #7
86TOYO2k17
So is a 2jz! lol.
Touché
Old 09-01-2019, 01:27 PM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
I am not able to find it here
Old 09-01-2019, 01:56 PM   #9
mrg666
pessimistic skeptic
mrg666's Avatar
Boostane looks like serious racing stuff. I was just hoping to add a tiny bit MMT to bump 91 to 93 octane without any change in tune and damaging cat/o2sensors. Maybe I could also try boostane in small amounts.
Old 09-01-2019, 02:40 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I have seen the difference Boostane makes, it actually works. VEMS tuning in Colchester Vermont uses it in some of the customer builds who want it. It allows for a bit more timing, usually 20-40wtq worth all together on the EJ257/FA20DIT motors
Old 09-01-2019, 02:53 PM   #11
86TOYO2k17
Any octane booster that actually works can shorten the life of cats and spark plugs. However boostane has minimized that effect with their formula to keep the MMT and other octane boosting ingredients in suspension as well as various cleaners/detergents. You can go to their website or download the app and calculate how much boostane you need to turn x gallons of y octane into desired z octane. Example 12 gallons of 91 octane to 93 octane requires 2 oz.
personally i think the new octane numbers may be inflated, so i would use at least double what it says. personally i use 1/3rd can or 5.34oz to treat 12gallons of 92 and probably have 94octane if I was guessing even though it says 97octane.
Most of those other octane boosters especially if it doesn’t have MMT raise octane by 1/10th of octane point per bottle. Its more for turning crap 91 into good 91. Like a bad batch or lower quality gas.
Old 09-01-2019, 04:03 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Or way to cheat petrol-only class requirement to E85 like performance boost?
Old 09-01-2019, 04:15 PM   #13
mrg666
pessimistic skeptic
mrg666's Avatar
High octane - good quality gas makes a big difference, especially after FI. I am having hard time finding a consistently good quality 93 octane in our area. My fuel pump has crickets when I use ethanol gas. And only nonethanol is 91 octane here with inconsistent quality. Every time I fill my tank I keep wondering if it will be a bad week again. That is why I am trying to take the control of my octane. I have Lucas Oil octane booster with MMT in the tank with 91 octane non ethanol. The difference is noticeable, engine is so much more smoother and responsive. I already have just replaced the cat and sensors together with a 2017+ header swap. I will do the same again in two-three years down the road again if needed. Thank you for useful input.
Old 09-01-2019, 04:17 PM   #14
mrg666
pessimistic skeptic
mrg666's Avatar
I could have tried that but I need to stick with JR CARB tune.
mixing e85 (109 octane) with e15 (91 octane) pcguru2000 Engine, Exhaust, Transmission 19 03-08-2022 10:35 PM
Octane Boosters will they give you more power steve99 AFRICA 45 08-25-2018 03:24 PM
100 Octane? hellyvin Northern California 23 07-24-2017 08:01 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
93 Octane? ashtray BRZ First-Gen (2012+) — General Topics 175 04-04-2012 12:22 PM
