Old 08-26-2019, 10:01 AM   #1
sqd
sqd's Avatar
Drives: '13 SWP GT86
10 inch tablet mount?
Does anyone have a good solution how to mount a 10 inch tablet (portrait orientation), and not block the headunit or climate controls etc?
I use one with my Ecutek bluetooth interface to monitor things. Would be nice to have it mounted for easy overview.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 08-31-2019, 11:53 PM   #2
nwgabrz
Drives: BRZ Limited
You can use either the Arkon arm grip or the Beatsonic dash holder. I've used both and I'll see if I can upload photos later.
nwgabrz is offline   Reply With Quote
Old 09-01-2019, 06:40 PM   #3
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
I haven't tried this one but I think it might work:
https://www.amazon.com/dp/B00A2AEEGE/
LimitedSlip is offline   Reply With Quote
Old 09-05-2019, 11:51 AM   #4
nwgabrz
Drives: BRZ Limited
Here are the photos.
Beatsonic mounted horizontally
Beatsonic mounted vertically
Arkon arm grip mounted horizonally
Arkon arm grip mounted vertically
For both the Beatsonic and Arkon ones, I switched out the plate for the Scosche magnetic joint so the tablet has the flat magnet in the back. If you want it to be more secure, you can always use the normal grip, but I wanted something that I could more easily mount and dismount, and be cleaner.
edit--
As you can see, I also had mounted it on brackets over the climate controls as well.
Last edited by nwgabrz; 09-05-2019 at 12:06 PM. Reason: As you can see, I also had mounted it on brackets over the climate controls as well.
APR GT250 67 Inch wing w/ 7 Inch risers on SEIBON CSL Style CF Trunk Tony.86_ Exterior Parts (Aero, Lighting, Etc.) 5 01-03-2020 10:03 PM
FS: OpenFlash Tablet w/ ProClip mount and cable $450 shipped cruizin01 Engine, Exhaust, Bolt-Ons 1 08-14-2015 08:59 AM
Any idea to mount tablet on seat rail?? Mikeez Issues | Warranty | Recalls / TSB 10 09-08-2014 12:28 PM
8 inch tablet possible? bgibbsunc Electronics | Audio | NAV | Infotainment 15 03-15-2014 08:36 PM
Amp wiring help + 3d printed tablet mount transition Electronics | Audio | NAV | Infotainment 9 03-04-2014 08:41 PM
