Drives: 2019 Subaru BRZ - JDL Turbo Kit
exhaust and headers upgrade
Hi everyone! So I just purchased a 2019 Subaru BRZ Limited and I'm reaching at 1.5k miles now. I am thinking around 5k to replace the headers and exhaust to get rid of that torgue dip. I do want the boxer rumble, but nothing too loud since I do live in California in the Bay Area (also new the area so I don't know how lenient cops are around this area).
However, I was looking at the FT86 Catted UEL and Corsa Exhaust for the car. Some things I did have in mind were not getting a CEL light and worrying about that and whether I should get a tune done from a professional shop or if I should go with OFT or EcuTek. Many people have told me to go EcuTek route if I want to do forced induction however, I am not planning on doing that for quite some time. Wanted some other opinions on doing this to my car. Also, would I have to do exhaust and headers at the same time or can I do exhaust and then headers or vice versa and do a tune a few months down the road. |
Catback does not require tune. You can do this at anytime. Cat or no cat aftermarket headers are illegal. Here is what I would due.
OFT tune Tomie UEL catless/JDL UEL/ Gruppe-s UEL Keep stock front pipe and overpipe Catback options MXP SP R400 CSG touring These would be my top picks. I would due the header with OFT tablet. See how you like the noise with just a header. From their you can judge how much louder or tone you want. Hope this helps Sent from my GM1915 using Tapatalk
2013 Series 10 FRS #553
September
Drives: 2015 BRZ
It all depends what you want from your car tbh. If you just got the car and your not experienced with fast cars then i would stick with exhaust mods first. In our chassis, only way to get more power is to FI. if you don’t want to go to that route then UEL header with stage 2 tune is probably best for your money. Car parts are expensive and if you have enough money for a tune/oft and a UEL header then yes. if not enough money then just do exhaust first.
I have done catless front pipe and top speed pro 1 axle back. it’s loud enough for me and no drone, best of all i get some loud pops and crackles with my set up. |
Drives: 86
This thread explains more about CEL with catted header and OFT vs EcuTek.
http://www.ft86club.com/forums/showthread.php?t=132435 I would have gone header first if I wasn't so determined to go FI lol. I also second MXP SP catback. |
Drives: 17 Asphalt 86
Get an OFT. If you find one used you can buy/sell without losing money in most cases. You'll get the more out of the header even with an off the shelf tune.
When you decide to go F.I sell the OFT. |
Drives: 2013 frs red
I would leave exhaust stock. Buy header only. Rest of exhaust is alot of money with little performance gain. Oft will work well as will ecutek. Your choice. E85 will give you max na results.
| The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post: | NoHaveMSG (08-25-2019), PulsarBeeerz (08-25-2019) |
Original poster... See a common theme developing... Tune+header = bang for buck. NA used oft. Once you go FI then get ecutek.
Granted the best NA performance is ecutek tune plus ACE 350 via DD or now CSG in house tuning. This is big bucks but it will give by far the best NA gains... Cheap and basic FI can destroy this for not alot more than the ace setup. Lots of options. Do your homework and you will make the right decision. Sent from my GM1915 using Tapatalk
Cough, decat oem system and Ecutek tune, cough
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
Don’t waste your money on headers, ESPECIALLY catted headers. The 2017+ exhaust is already good. Just pay for a good tune. Go E85 if you can.
#10 |
Drives: Bone stock
| The Following User Says Thank You to Joveen For This Useful Post: | HachiRokuX (01-08-2020) |
#11 |
#12 | |
Then Replaced cat back to OEM with zero change to performance, knocked down the noise a bit Then Replaced 17+ punched out header with Tomei UEL header, zero performance gain, lots more noise though, put OEM header back on because I'm not a **** and care about my neighbors sanity and hearing. For NA The OEM system flows great once the restrictions are removed.
#13 |
Drives: Bone stock
Impressive
Sent from my SM-N960U using Tapatalk |
#14 | |
| Front pipe / Quad Tip Exhaust / Light Weight Race Exhaust / Unequal Length Headers | JonMotoring | Engine, Exhaust, Bolt-Ons | 314 | 01-22-2016 12:19 PM |
| Exhaust upgrade | jonnyfrank | Engine, Exhaust, Transmission | 4 | 10-14-2015 09:52 AM |
| Looking to upgrade exhaust | vitti821 | Engine, Exhaust, Transmission | 6 | 03-29-2015 01:22 PM |
| Exhaust: When to upgrade? | Dream20b | Engine, Exhaust, Transmission | 3 | 11-17-2014 09:23 PM |
| Exhaust Mod/Upgrade 101? | Re~Mix | Engine, Exhaust, Transmission | 1 | 07-02-2012 05:23 PM |
