Old 08-19-2019, 03:26 PM   #1
sqd
sqd's Avatar
Drives: '13 SWP GT86
Wideband O2 into ECU
Okay, so I have a AEM X-series wideband gauge (p/n 30-0300) with included LSU 4.9 sensor hooked up to my ECU by replacing the stock secondary one. I did this so Ecutek could use the wideband instead of the stock front one, for more precise logging etc.
Problem is, car is running very rich and the readings are kind of erratic and weird..
But does anyone know if I need to program/do anything with the gauge/controller for it to send the right signal to the ECU? I have a friend who knows a little about tuning, and he said that was needed on the sensors he has used in the past, though that was never for a Canbus car such as ours are, nor with Ecutek (he has used standalones).
Any help is greatly appreciated.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 08-19-2019, 03:53 PM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
The AEM scaling is pretty standard 0-5v. Make sure whoever made the Ecutek map set it up right for a wideband rear o2
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 08-19-2019, 05:48 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
How does it read at lambda 1 compared to the OEM primary O2? Is the power to the AEM clean?
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-20-2019, 04:02 AM   #4
sqd
sqd's Avatar
They are aware, I'm thinking it's something else.. that's why I was thinking if I needed to do anything after wiring in the wideband on the stock wiring for the OEM secondary O2.
I've PM'ed you
I have a ACE header, I hope I've installed the primary O2 in the right bung, same with the secondary/wideband..
Pretty sure the wideband is installed in the "lower" bung, the one closer to the ground, and the primary on the one closer to the engine. No idea if that matters.
IG @squareddesign
Old 08-20-2019, 05:59 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Try reading this thread.....
Wouldn't matter too much. You want the OEM one closer ideally for closed loop fuelling for cruise, at WOT I would expect closed loop fuelling based off the WBO2 so this would be ideally better closer but exhaust velocity is higher, thus it matters less.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
sqd (08-21-2019)
AEM Wideband help ppbiggums Forced Induction 3 06-15-2015 10:36 AM
wtb injector aem wideband kcam86 Want-To-Buy Requests 0 04-13-2014 08:46 PM
Wideband Admired Forced Induction 101 02-26-2014 11:50 AM
Wideband power. From ecu or elsewhere? Bigmaxy Electronics | Audio | NAV | Infotainment 6 02-25-2014 05:20 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
