Old 08-15-2019, 12:09 AM   #1
hachigoku
Drives: BRZ, E90 M3
Valve Spring Recall – Not Original Engine
Hi,
So I am not able to register my car until I have the valve spring recall done for my 13 BRZ. The issue is that my engine was replaced last year. I shot a valve through my valve cover.
The engine in my BRZ is from a 2015. Since the engine is not under the same range would the dealer be able to remove the notice or have some type of documentation that my engine is not affected by the recall?
My apologies if this has already been covered, but there is a vast sea of information out there and it's tough to find what I need.
Thank you so much!
hachigoku is offline   Reply With Quote
Old 08-15-2019, 12:58 AM   #2
JDM_GT86
JDM_GT86's Avatar
Drives: 2013 Scion FRS
I would contact the dealer, sounds reasonable to just remove the recall.
JDM_GT86 is offline   Reply With Quote
The Following User Says Thank You to JDM_GT86 For This Useful Post:
humfrz (08-15-2019)
Old 08-15-2019, 02:26 AM   #3
humfrz
I'd suggest you get some documentation (unless you have it) that the engine in your car is a 2015 engine. Then go to a dealer and ask them to sign off on the recall.
humfrz
Old 08-15-2019, 07:07 AM   #4
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Sounds like a great reason to leave the state of california.
The Following 11 Users Say Thank You to why? For This Useful Post:
BRZyJ (08-17-2019), Cartman (08-16-2019), Dadhawk (08-15-2019), DarkPira7e (08-28-2019), Grady (08-28-2019), gravitylover (08-17-2019), NWFRS (10-12-2019), shellslinger (08-19-2019), soundman98 (10-20-2019), spike021 (09-03-2019), weederr33 (08-29-2019)
Old 08-16-2019, 09:59 PM   #5
hachigoku
Drives: BRZ, E90 M3
Got it, thanks friends!
The Following User Says Thank You to hachigoku For This Useful Post:
humfrz (08-17-2019)
Old 08-20-2019, 01:43 PM   #6
DarkSideFRS
Drives: 2013 pearl white FR-S
just curious, but did your registration renewal actually states that u need the recall done to register the car or are you basing this off the recall letter? I renewed my tags a couple months ago and was not required to do the recall... yet... just wondering if they're starting to enforce it now... if it indeed is on the registration renewal, do u mind taking a picture of it..? thanks!
DarkSideFRS is offline   Reply With Quote
The Following User Says Thank You to DarkSideFRS For This Useful Post:
Lantanafrs2 (08-28-2019)
Old 08-28-2019, 10:51 AM   #7
acuatlsfan
Drives: whiteout
Originally Posted by hachigoku View Post
Hi,
Thank you so much!
Was 2015 motor a direct swap with 2013MY? Any modifications required or reprogramming required?
I have a spun bearing at the moment, trying to see what my options are.
acuatlsfan is offline   Reply With Quote
Old 08-28-2019, 12:12 PM   #8
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
curious about exactly the same thing too.
shiumai is offline   Reply With Quote
Old 08-28-2019, 12:23 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
humfrz
They should be able to gather that from the VIN I imagine
Old 08-28-2019, 01:07 PM   #10
humfrz
But, wouldn't the VIN reflect the old (original) 2013 engine and not the 2015 engine that replaced it?
humfrz
Old 08-28-2019, 09:39 PM   #11
finch1750
finch1750's Avatar
humfrz
There's a VIN on the engine itself iirc. They put that shit everywhere now a days.
humfrz (08-28-2019)
Old 08-28-2019, 09:43 PM   #12
humfrz
Oh - I reckon I should open the hood more often -
humfrz
Old 08-28-2019, 09:44 PM   #13
finch1750
finch1750's Avatar
humfrz
Well I could be wrong. I started looking around online for it and it may be an engine block ID, which may or may not help still.
humfrz (08-28-2019)
Old 08-28-2019, 09:53 PM   #14
humfrz
Well, that does give me an idea for the OP.
Just record the engine block ID and show it to whoever and explain that that proves that it is a 2015 engine -
humfrz
Dadhawk (08-29-2019), finch1750 (08-29-2019)
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 06:21 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 12:10 AM
Potential diminished value from valve spring recall and engine failure? Andxzng Issues | Warranty | Recalls / TSB 2 04-08-2019 03:06 PM
engine valve spring recall done but giant oil leak msaikhan Issues | Warranty | Recalls / TSB 1 02-24-2019 06:18 PM
valve spring recall-engine oil leak TYinhouse Issues | Warranty | Recalls / TSB 13 01-17-2019 11:09 AM
