Old 08-14-2019, 08:09 AM   #1
Tom Brady
Drives: 2015 Scion FRS
Tomei UEL Headers
I am looking into getting the Tomei UEL Headers. But, the kicker is that I plan on going big turbo in the next year. My question is, will I be able to still run the Tomei UEL Headers with my big turbo? I'm not sure if the headers will fit the big turbo, based off I guess each big turbos sizing is different. I'm not sure, thats why I am asking y'all.
Tom Brady is offline   Reply With Quote
Old 08-14-2019, 08:20 AM   #2
Lantanafrs2
Drives: 2013 frs red
No they wont
Old 08-14-2019, 08:20 AM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Short answer: No
A header is for NA or supercharged applications. In a turbo setup, you'll need a turbo manifold.
BigTuna is offline   Reply With Quote
Old 08-14-2019, 08:22 AM   #4
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
Get the JDL UEL turbo manifold and blank that bitch off.
Howaitoguru is offline   Reply With Quote
Old 08-14-2019, 08:27 AM   #5
Howaitoguru
You could like get a gasket and some quarter inch sheet metal and fab out a blank plate and use a vice to drill out the holes for the bolts and just torque the bolts down so you have no exhaust leaks. Then when you’re ready for boost you can take the plate off and throw on your turbo kit.
Old 08-14-2019, 08:30 AM   #6
Tom Brady
Okay so it's noted if I run the Tomei UEL Headers, I will have to take it off when I go big turbo. If I wanna do headers now, what should I buy, if I am going big turbo here in the near future soon
Old 08-14-2019, 08:36 AM   #7
Howaitoguru
Do what I said which I don’t honestly 100% recommend as I don’t know if anyone has done this. Otherwise you just need to wait.
Old 08-14-2019, 08:36 AM   #8
Howaitoguru
Or you can buy used and sell later so you get most of your money back.
Old 08-14-2019, 08:39 AM   #9
Turdinator
Señor Member
Turdinator's Avatar
The Ptuning kit uses your existing header in their turbo setup. It is pretty unique tho.
1974 TA22 Celica
2013 86 GT
Old 08-14-2019, 08:54 AM   #10
86MLR
86MLR's Avatar
Just wait and don't piss money away
I found no performance gain when I put a Tomei UEL header to replace a catless (punched out) OEM header
I actually reinstalled the OEM header as there was no performance advantage and rhe UEL header was obnoxiously loud
Opinions may vary
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 08-14-2019, 09:25 AM   #11
BigTuna
BigTuna's Avatar
What? You're suggesting installing a manifold then blocking it off? Where would the exhaust gasses go?
If you want to do a header before you go turbo, I'd buy a used one and then resell it when you do the turbo kit. You'd lose less money than buying a new header. You'd still need a tune to gain any performance and clear CEL codes which is another added cost.
Or you could just keep the stock header until you get the turbo kit. No sense in doing an install if you know you're going to turn around and take it back off..
Old 08-14-2019, 09:39 AM   #12
Howaitoguru
Nah you’d block off the turbo exit and mount it as if it were a normal header. There’s probably a lot more to it than that.
Old 08-14-2019, 10:23 AM   #13
Lantanafrs2
Save your money
Old 08-14-2019, 10:25 AM   #14
Lantanafrs2
Lmao no shit
Sent from my iPhone using Tapatalk[/QUOTE]
Tomei UEL vs HKS/Tomei EL headers for gains max20s14 Engine, Exhaust, Transmission 37 05-28-2020 09:11 PM
WTB JDL/P&L/TOMEI UEL Headers v86 Want-To-Buy Requests 8 08-27-2018 02:49 PM
WTB: Tomei UEL headers WolF_RS Want-To-Buy Requests 0 06-29-2016 11:34 PM
WTB Tomei Type 80, Tomei UEL headers Justin91M Want-To-Buy Requests 1 12-19-2014 11:42 AM
