Drives: 2014 BRZ
FA20 Part Guide Resealing Engine
Hey Everybody,
I tried to order the seals without the OEM head gaskets for a rebuild I'm attempting however I found it cheaper to order the whole kit. A lot of places are charging $222 for this same seal kit. You can either buy the whole kit for $141.20 + shipping: 10105AB550 Or you can buy the broken out list below for $180.43: Part No. Part Name QTY 806792010 OILSEAL -92X109X8 1 806916080 O RING-16.1X2,3 2 11044AA810 GSKT -CYL HEAD 1 10944AA100 GSKT-CYL HEAD,2 1 10966AA041 GSKT-SPARK PL PIP 4 806915170 O RING-15.4X1.8 4 803916010 GSKT-16X21X2.3 1 806932030 O RING-32.6X2.7 3 806939060 O RING-39.0X2,0 1 806924120 O RING-23.8X2.8 1 806912190 O RING-12.1X2.5 3 806750080 OILSEAL -50X62X7 1 15090KA000 SEAL-OIL LEVEL 1 13270AA250 GSKT-ROCKER COVERRH 1 13272AA180 GSKT-ROCKER COVERLH 1 14035AA610 GSKT-INT MANIF 2 17555AA040 GSKT -FUEL PIPE 1 806931110 O RING-31.5X2.0 1 806933010 O RING-33.7X3.5 2 44011AC030 GASKET F 2 Thought it was something interesting; hopefully it helps someone out. - Mark |
Drives: 2017 Subaru BRZ Limited
Great info, thanks.
I don't see the five gallons of Three Bond RTV Silicone you will need as well.
https://www.amazon.com/dp/B008Y60R5K...yoheadqucom-20
#4 | |
Drives: 2014 BRZ
This is indeed missing, Subaru should add this to the kit. |
Drives: 2013 FRS
As many of these that have problems leaking, people still think three bond is the best sealant option?
Yes. When applied properly. The issue isn’t with the sealant since all FA20s use it with out many issues. The problem is that some get sloppy when removing and reapplying it.
#7 | |
I came to the same conclusion when rebuilding my engine. I did add a few other things that were not in the kit like HP injector seals and OCV filters. I used three tubes of TB1217H but the third tube was hardly used and I actually resealed the cam subs trice because I accidentally rotated my box of shims which screwed my lash. |
| ECU and Engine Tuning Reference Guide | swift996 | Software Tuning | 140 | 11-02-2022 12:18 AM |
| [FS] 2013 FA20 part-out | ML | Engine, Exhaust, Bolt-Ons | 5 | 12-12-2018 03:36 PM |
| Headlight resealing in SoCal | CatalystPLUR | Southern California | 6 | 07-06-2017 03:53 PM |
| Looking to buy FA20 engine | ndreim | Want-To-Buy Requests | 0 | 12-15-2015 06:43 PM |
| Engine Sensor OBD II Guide | swift996 | Software Tuning | 4 | 01-10-2014 04:48 PM |
