Old 08-03-2012, 06:57 AM   #1
Zadkiel
Drives: CBS BRZ Limited 6MT
Loud metal ping from rear
As described. Only has happened once so far, hard left in a corner at 50ish mph. Sounded almost like something metal popped off then pinged against the road. Quick underbody inspection noted no damage, and it seems as all the bolts are in their respective places. I'll do a more detailed check later today. No noted handling differences either. I didn't notice any road debris. Being paranoid or has this happened to anyone else?
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 08-03-2012, 08:43 AM   #2
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Scary. Havent heard anything like that myself. Make sure to check your lug nuts if one was over torqued it could have sheered under load.
RandomHero is offline   Reply With Quote
Old 08-03-2012, 05:06 PM   #3
Zadkiel
No noted re-occurances. Might just be me being paranoid.
Old 08-03-2012, 05:10 PM   #4
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
If you can't reproduce it, maybe something was there on the road and you stepped on it and it flew away?
Sigh-on-Rice is offline   Reply With Quote
Old 08-03-2012, 05:38 PM   #5
mRdeMs83
mRdeMs83's Avatar
Drives: Argento FR-S 86
I get this sound also. Usually when going in to 5th at about 60 mph... right side back tire area.....sounds scary.
mRdeMs83 is offline   Reply With Quote
Old 08-03-2012, 05:44 PM   #6
Shagaliscious
Drives: Firestorm FR-S (MT)
Maybe it was a rock/screw on the road that got kicked up by your tire and hit the underside of your car?
The way you describe it I think I have had a similar experience, but I just dismissed mine as something on the road getting kicked up and hitting the underside of my car.
Anyone heard any loud popping? Kimsey47 BRZ First-Gen (2012+) — General Topics 103 07-30-2013 09:27 PM
SOUND LEVEL TO LOW!! Not loud enough Hbomb Electronics | Audio | NAV | Infotainment 24 12-21-2012 09:02 AM
Waterjet metal cutting? DarrenDriven Northwest 18 09-14-2012 10:13 PM
Freed Engineering custom metal fabrication and parts development bFreed Announcements, Contests, Giveaways 23 03-24-2012 03:35 AM
I've seen the GT86 in the metal and... Craikeybaby Scion FR-S / Toyota 86 GT86 General Forum 37 12-13-2011 03:57 AM
