Old 08-12-2019, 02:38 PM   #1
beepinheimer
Drives: 2013 - Scion FRS
Crank Pulley install help
Tried installing a lighter weight crank pulley this past weekend and the pulley spacer came out.
Once reinstalled the belt jumped off and I noticed that the pulley and spacer weren't flush up against the block.
I removed everything and reinstalled everything, nothing looks sheared or broken.
Is this going to affect the timing at all?
Image galley link is down below. Thanks!
http://imgur.com/a/iHuyEr9
beepinheimer is offline   Reply With Quote
Old 08-12-2019, 05:07 PM   #2
Contender
Drives: 2017 Toyota 86
Oh boy does not sound good. I just put on my kit water pump, crank, and alternator pulley. Was very careful to not let the spacer on the crankshaft come out. I can say I feel a difference especially from 1st to 2nd gear is smoother if you will. I am happy with the results haters hate but to me it feels better all around. Hope you didn't F something up.
Contender is offline   Reply With Quote
Old 08-12-2019, 07:51 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
It won't effect your timing. The spacer drives the oil pump only.
1974 TA22 Celica
2013 86 GT
crank, pulley, spacer, sprocket
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
[GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt reeves Engine, Exhaust, Bolt-Ons 0 08-22-2018 07:01 PM
DIY - Lightweight crank pulley install (Perrin) justinco DIY (Do-It-Yourself) Guides 11 05-22-2017 04:35 PM
Perrin Crank Pulley Install (time lapse vid) ninjasaurusrex DIY (Do-It-Yourself) Guides 0 03-12-2014 01:42 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
