Old 08-11-2019, 02:19 PM   #1
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Best offset for 17x9 for AutoX/track?
Hey folks,
So I've been researching various 17x9 wheels lately and was wondering what is the "best" offset for things like AutoX and track days.
There was a related question in the past:
Originally Posted by jvincent View Post
do you guys run the same offset as stock or slightly less, i.e. not enough to be flush but a little less than stock to get a just a little bit wider stance?
which CSG Mike answered:
Slightly less, but because we need to clear the suspension.
Based on that response, I'm under the impression that the smaller the offset (less poke / more tuck) the better.
APEX Race Parts say that the sweet spot is around ET40–42:
Originally Posted by APEX Race Parts View Post
9" wide wheels are the maximum wheel width we can stuff under the car with the stock suspension in place, and we believe the sweet spot for offset is ET40-42.
However, for some reason various 17x9 +35 wheels are very popular (RPF1s, TC105N, TC105X) among FT86 enthusiasts.
Titan 7 Wheels claim they purpose-build their wheels to specific cars, and for FT86 their T-S5 17x9 offering is +37.
I'm a little confused here, to be honest.
Some of the other concerns I've seen are:
  • Around +42 is the highest you can go with stock suspension
  • +40 and higher offsets are more likely to rub the inner fender
  • At lower offsets (around +35) you need significant negative camber to avoid excessive poke / rubbing the wheel arch / popping the side marker
  • The higher the offset, the less room for adjustment you have with camber bolts, having zero room around +42, and some even reported issues with +40 wheels.
    I know some folks max out their camber at the camber plates and end up also using camber bolts.
  • Stock offset is +48, so the lower the offset you get, the more you change the scrub radius from the intended value — at what point does this start to matter? Does camber also affect the effective scrub radius?
In case it matters, I have CSG Spec TEIN Flex A pending install, so I might have a bit more room for the wheel if offsets even higher than +42 are beneficial. Also, I plan to run GT Radial SX2 245/40R17 for at least some time after I get 17x9s.
timurrrr is offline   Reply With Quote
Old 08-11-2019, 07:54 PM   #2
Cole
Not a troll
Cole's Avatar
I'm running +35 (+32 effective with a 3mm spacer), with about -3* of camber with stock struts and tein lowering springs.
Realistically, if you're asking this question, you're not actually good enough for it to matter. Since you have coilovers pending install, your wheel choice comes down to whatever you think is prettiest at the price you want to pay.
Old 08-11-2019, 08:24 PM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
i have 6ULs with csg flex As. there is plenty of room to spare with my brembos, the coilover, and wheel well
Breadman is offline   Reply With Quote
Old 08-11-2019, 08:54 PM   #4
rt
@rayhere
rt's Avatar
+38 with 255/40 tires and -3.1* camber didn't rub for me on the track.
rt is offline   Reply With Quote
Old 08-11-2019, 09:28 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I rubbed a bit when really low with +42 and -2.7 camber. Id go +35 if possible. I just raised it a bit and put on 3mm spacers and have been good since.
If tracking/auotx you need camber anyway so inner clearance is the bigger need, hence the lower offsets
Old 08-11-2019, 10:14 PM   #6
KevBRZ
Drives: 15BRZ
wheel setup
FWIW, I just installed +35 offset 17 x 9 wheels with 245/40/17 tires, they will poke some and the bad thing is you really can't dial in much negative camber up front at all or tire will hit the stock spring perch in the front, i don't know exactly how much negative camber i have but probably less than -1 and i only have a few mm maybe 3 from the perch just enough to barely slip a piece of cardboard in the space but snugly . i kinda wondered if my tires were oversized a bit (rivals)
i plan on going with coilovers shortly anyhow but just in case you were interested.
I am not sure how Cole above is running that setup unless he has more narrow wheels and tires.
KevBRZ is offline   Reply With Quote
Old 08-11-2019, 10:24 PM   #7
Cole
Not a troll
Cole's Avatar
“More narrow wheels and tires”? What does that even mean?
My set up is as follows:
RE71R 245/40/17
720Form GTF1 17x9
3mm spacer
Tein S Tech springs
Camber bolt in the top hole, set to max negative camber
Silver Project top hats, also maxed for negative camber
Old 08-11-2019, 10:32 PM   #8
KevBRZ
Drives: 15BRZ
RE71R 245/40/17
720Form GTF1 17x9
3mm spacer
Tein S Tech springs
My bad , I was thinking maybe you had 17 x8 wheels and maybe 235 series tires, i only got a camber bolt in the bottom hole and if its maxed out i am literally hitting the perch. Weird. i had to back out the camber to clear the perch.
Old 08-12-2019, 12:02 AM   #9
It all depends on how you get the camber, and your specific tire.
There is no one size fits all, if you want to push the limit.
+37 is the size chosen for CSG spec TWS T66-F and Titan7, because that is the highest that will clear any reasonable variant of tire and camber modifier on stock suspension.
Old 08-12-2019, 10:42 AM   #10
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Thanks everyone for the data!
Can you please elaborate, assuming e.g. 245/40 GT Radial SX2, camber bolts and camber plates?
Would you pick a different offset for non-stock suspension, e.g. CSG Spec TEIN Flex A?
Sure, just want to better understand the trade-offs and known good recipes before making a $1k+ purchase.
Not unlikely, but the whole purpose of me buying and modding the car is to learn more and get better. Don't want to learn by making expensive mistakes that are easy to avoid by doing a bit of homework, and I'm sure someone else will later benefit from the knowledge we exchange here.
You'll probably want camber plates, see:
For performance driving enthusiasts looking to increase handling performance while gaining more outer fender clearance (in order to stuff wider compounds onto the wheel), adjustable camber plates are the real solution. Camber/crash bolts are a band-aid fix and can only net you so much camber.
Old 08-12-2019, 10:49 AM   #11
ka-t_240
I have 17x9 +42 and 35.
The +42 will rub on the inner fender/front on the front. I have had 3 different sets of 245 or 255 on it and have slight rub. The +35 have never rubbed anywhere.
ka-t_240 is offline   Reply With Quote
Old 08-12-2019, 10:50 AM   #12
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by timurrrr View Post
  • The higher offset, the less room for adjustment you have with camber bolts, having zero room around +42.
Found some interesting old discussion on this topic and specifically this post that says that generally one should get most of the camber from the hub, not the top mounts.
Old 08-12-2019, 11:00 AM   #13
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Which offset, +40?
Old 08-12-2019, 11:36 AM   #14
KevBRZ
Drives: 15BRZ
You'll probably want camber plates, see:[/QUOTE]
Actually with 2 camber bolts on each side or 1 camber and 1 crash bolt you can get alot of negative camber , i am going to use coilovers that will have camber plates but i am going to try to get as much negative camber i can from the lower holes not the plates, they are slotted on the coilover so with just a crash bolt i might be pretty good and i don't think you are supposed to use camber bolts on coilovers due to slippage but i am by far not an expert on these matters lol
Looking for 17x9 35 offset RPF1 jamies31 Canada Classifieds 0 05-30-2017 06:04 PM
WTB: 17x9 wheels and tires, +42-46 offset luchadorjose Want-To-Buy Requests 2 05-02-2017 03:39 PM
Volk TE37V 17x9 36 offset NEW Scoobyrs25 Wheels and Tires 17 12-06-2015 05:36 PM
Enkei rpf1. 17x9+35 offset Geeteepee Southern California 4 01-27-2015 07:12 PM
Best offset for RPF1 (+35 or +45) in 17x9 and track/AX use dp1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-19-2014 04:01 PM
