Drives: 17 BRZ Series.Yellow
Looking for track pad recommendations
As the title states.....
Car is a 17 Yellow Series with Brembo's. I consider myself to be an advanced driver. I've been using Hawk HT10's, but want to try something different. I run tracks in the Northeast (Club Motorsport, Palmer Motorsport Park, NHMS, Thompson Speedway and Lime Rock). I'm not crazy heavy on the brakes, but I also don't have any brake cooling ducts. I like strong initial bite with good modulation. I swap pads at track, so not concerned with dust or noise. Currently running 225 Nitto NT01's. Also use Castrol SRF fluid. Perrin master cylinder brace. I have stainless lines but haven't installed them yet. Winmax? CSG Spec pads? Project Mu? Hawk DTC's? PFC? What are people running and what is your feedback? Thanks! Sent from my Pixel 3 using Tapatalk |
Drives: Crapcan
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
Drives: Subaru BRZ
Ferodo DS1-11, love them.
#4 | |
| The Following 2 Users Say Thank You to CSG David For This Useful Post: | strat61caster (08-03-2019), wparsons (08-03-2019) |
#5 | |
).Budget depends on longevity. I don't mind spending money on parts that will last and are good. No one wants to buy an expensive part and either hate it or blow through incredibly quick. Goals would be to try a new pad that outperforms the HT10. I think the hard part I've found so far, is finding decent compounds for the PP calipers. What would you recommend for CSG Spec pads? Assuming this is a private label pad, who makes them for you (happy to discuss via PM). Thanks for the help and discussion! Sent from my Pixel 3 using Tapatalk |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Because you're swapping pads at the track (good on you), I'd recommend Carbotech XP12 in the front (CT1001-XP12) and XP10 in the rear (CT961-XP10).
They are a fairly high torque pad, have great modulation, they dust like crazy (but who cares, also the dust in non-corrosive and literally washes off with water after the track day). The only negative is they are pricey, but it turns out that you get what you pay for in this world.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
#7 | |
If modulation is key, go CSG pads. If big friction is your thing, go Raybestos, but know your brake pedal will be an on-off switch with NT01. Are you looking for *bite* or *response*? What about release? Pad friction stability? |
#8 | |
As stated before, I like really good initial bite as it tends to make me feel confident going deep into the brake zone. From there good modulation is important as I tend to trail brake a lot. Happy to try CSG pads. I'm not familiar with them at all, so interested to hear feedback about them. Sent from my Pixel 3 using Tapatalk |
Drives: Scion FR-S 10 Series
I DD a set of CSG spec pads on the stock size brakes. I love them!
#10 | |
Braking systems do need to match the tires for optimal results. Raybestos pads on the factory braking system will be on-off with NT01, but will have great modulation with Hoosiers. Likewise, RS29 on the factory braking system will modulate great with street tires, but will have an extremely long brake pedal with Hoosiers. |
#11 | |
The HT10's are good, but not great. I don't have 100% confidence with those. Hoping to find a better set up. The hard part about racing pads is that it's a lot of money to "try" something. Sent from my Pixel 3 using Tapatalk |
#12 | |
#13 | |
![]() Also scrolling through the page - since you're experienced in the Pagid RS29, you'll know how screechy those pads are, but they do survive some hard brake applications up about 50% pad life. On top of that, you'll also find the pads to clunk on some M-applications and rightfully so since the pads are slightly undersized. Our CSG C1 pads are available for F-body M brake applications which fit perfectly so there aren't any clunking issues as well. Unlike the PFC competition, these pads don't have the infamous brake noise and will work in cold to hot applications. |
#14 | |
Drives: '23 BRZ
I also ran Project Mu CRs, not as loud but not as much bite it seemed to me. Currently running PFC 11s on the Cayman, and they're fine for me as a track pad and drive-to-and-from track, no real complaints on them... IMO, not necessarily... Different drivers running similar lap times, even in the same car, can place very different demands on brakes! It is possible to be a fast driver and relatively "easy on brakes", it is also possible to be a not-so-fast driver and be overusing the brakes. |
| The Following User Says Thank You to ZDan For This Useful Post: | CSG Mike (08-04-2019) |
| Recommendations for track pads better than PMU HC800+? | DarkSunrise | Tracking / Autocross / HPDE / Drifting | 32 | 03-10-2016 03:21 PM |
| Track-Only HPDE Brake Pad recommendations. Stock platform/calipers/rotors | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 08-20-2014 12:03 PM |
| Track-only Race Compound Tires recommendations & Q's. On stock wheels. | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 03-26-2014 11:47 PM |
| Track pad setup recommendations | orthojoe | Tracking / Autocross / HPDE / Drifting | 15 | 02-25-2013 07:18 PM |
| Need Tire recommendations please, non track use | JoeBoxer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 01-03-2013 04:15 PM |
