Old 07-25-2019, 12:07 PM   #1
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
245/45/17 tiresize and OEM suspension
Has anyone run 245/45/17 on OEM suspension? I am wondering if it will fit? If it did fit was your offset and did you have to use spacers?
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
Leonardo (07-25-2019)
Old 07-25-2019, 12:10 PM   #2
strat61caster
strat61caster's Avatar
https://www.google.com/search?q=ft86...ock+suspension
45 is odd choice for this car, much larger diameter, fewer tire choices iirc, 245/40/17 matches OE tire diameter and has more options
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
Elliotw (07-25-2019), Nevermore (07-25-2019), Summerwolf (07-25-2019)
Old 07-25-2019, 12:12 PM   #3
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Why 245/45? The closest diameter to stock (which keeps your speedo mostly accurate) would be a 245/40. I don't suggest you run the 245/45. With stock suspension, a 245/40/17 on my 17x8.5 +38 wheels fits nearly flush and never had any issues. I think you can get away with a tighter offset, but others can shed more light on the "tightest" fit. I doubt it works with stock offset, +48.
Nevermore is offline   Reply With Quote
The Following User Says Thank You to Nevermore For This Useful Post:
Old 07-25-2019, 12:15 PM   #4
Elliotw
Elliotw's Avatar
Looks like 245/40 works with stock. I'm wondering 245/45.
Old 07-25-2019, 12:21 PM   #5
Impureclient
Drives: 2015 FR-S
Don't wonder, never wonder. Wondering won't end well.
Impureclient is offline   Reply With Quote
The Following User Says Thank You to Impureclient For This Useful Post:
Old 07-25-2019, 12:25 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
That was tricky to find... Here are 245/45/17 on OEM suspension...
http://www.ft86club.com/forums/showthread.php?p=2570748
I LIKE TIRES!
The Following 3 Users Say Thank You to Leonardo For This Useful Post:
Elliotw (07-25-2019), Spankopotomous (12-26-2020), strat61caster (07-25-2019)
Old 07-25-2019, 12:29 PM   #7
Elliotw
Elliotw's Avatar
Thanks for the help everyone.
Rear Suspension Clunking, front suspension groaning Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-14-2018 07:10 PM
OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 3 10-04-2017 06:56 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 10:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
