Old 07-20-2019, 12:04 PM   #1
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
How could i go about removing Velox Camber Plates mounting bolts?
I'm replacing them with longer bolts for use with the Subtle Solution 1" Aluminum lift kit.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 07-20-2019, 12:58 PM   #2
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Those aren't bolt, they're studs. I have no idea why you're doing a 1" lift on your car, but FWIW, you can get these out with a shop press. You should heat them a bit with a torch beforehand, but not too much, remember you're working with aluminum.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
strat61caster (07-20-2019)
Old 07-20-2019, 03:52 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Subaru rally life me thinks....
Old 07-20-2019, 04:38 PM   #4
humfrz
If you don't have a press, Bubba says you could try putting two nuts tightened together near the top of the stud, then (as @Tristor suggested) gently heat up the plate (only) with a torch, then rap on the top of the stud, where the nuts are, with a hammer.
humfrz approves of Bubba's suggestion (this time).
Old 07-20-2019, 07:18 PM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Put a socket under the stud head (so it’s touching the camber plate only) and then give the other end of the stud a good whack with a 3lb hammer. I’ve done that on plenty of aluminum coilover top hats and they’re fine.
Velox vs Raceseng Camber Plates ChrisSC300 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 09-21-2021 02:00 PM
Velox Blue Camber Plates New KDad2 Brakes, Suspension, Chassis 4 07-09-2019 07:26 AM
OEM dampers with RCE yellows and Velox camber plates Joesurf79 Brakes, Suspension, Chassis 8 03-19-2018 06:50 PM
FS: FT86speedfactory/Velox Camber Plates sebastiansim Brakes, Suspension, Chassis 2 08-09-2017 06:17 PM
KW V3- 7k Swift Springs, Velox Camber Plates byun Brakes, Suspension, Chassis 3 10-05-2016 01:20 AM
