Old 07-14-2019, 07:14 PM   #1
Geex
Spacers, studs, and lugnuts
Hey guys,
Currently running 18x9.5 et38 wheels, I purchased 3mm slip on spacers for the rear.
I've been reading around the forum that 3mm was the max on stock studs, i'm also still on stock lug nuts is this going to be a problem ? Will I have proper thread engagement ? Just want to be 100% positive.
Thanks.
Geex is offline   Reply With Quote
Old 07-15-2019, 12:18 PM   #2
Vital
Drives: 2015 BRZ
Originally Posted by Geex View Post
Hey guys,
Thanks.
i highly doubt you're going to need a 3mm spacer for the rears to fit, it should fit without the spacers. It might actually be a good idea to use a 3mm spacer up front because thats where you might rub. You can actually use stock lug nuts on wheels as our stock lug nuts are already 60 degree conical shaped. Also, are you on stock suspension and what tire size are you using?
Vital is offline   Reply With Quote
Ichiba 5mm Spacers w/Studs XanRules Wheels and Tires 14 04-03-2018 03:10 AM
Spacers for ARP studs recommendation theman233 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-13-2016 12:45 AM
5mm spacers in stock studs bhbnuckle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-09-2016 02:09 PM
spacers and stock studs abutterman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-17-2013 10:55 PM
H&R Spacers, ARP Studs, Muteki Lugnuts - ForcedFabllc.com ForcedFab_Jon Wheels and Tires 1 12-05-2012 12:45 PM
