Drives: 2013 Asphalt FR-S/2003 Honda Accord
5mm spacers in stock studs
Just wondering if 5mm spacers up front fits to stock studs.
Installed coilovers last night and front is slightly sunken in, so i purchased 5mm spacers to give more of flushness. I have enkei raijin 18x8.5 +45 Front and 18x9.5 +45 rear.
/scion
Drives: '13 86 M/T
I personally would not run any more than a 3mm spacer on stock studs. You may be able to dial some camber out of it once you get an alignment.
"Practice makes better. Only Senna is perfect." - CSG Mike
Drives: 15 BRZ LTD, 05 FXT
3mm spacers on stock, high quality bolt ons, or decent ones with the studs pressed out and ARP extended lugs if you want to do more than 3mm.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
Drives: 2005 Toyota Camry
Generally 3mm is max.
However you have to keep in mind something: spacer thickness is not what matters, it's how many full turns of thread you can get with your lug nuts. Without knowing secondary info such as wheel lug seat thickness, it's hard to tell you definitively if 5mm is safe or not. -alex |
I have muteki sr 48 forged lugnuts. What do u thnik?
Sent from my Nexus 5X using Tapatalk |
#6 | |
Drives: 2014 whiteout, scion fr-s
im running 1/4 inch spacers(6.35mm) in the rear for 2 years now and im doing fine. however, this is the absolute max i would run spacers on... |
| FS: B2 10mm spacers+studs (4), MN | Nate. | Wheels and Tires | 2 | 03-05-2016 08:31 PM |
| Spacers with aftermarket studs? | Crestwood1001 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-19-2015 10:31 PM |
| H & R spacers 5/15mm, ARP studs | jack43 | Wheels and Tires | 4 | 11-21-2014 06:04 PM |
| Spacers and stock wheel studs | solidONE | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-31-2013 08:55 AM |
| spacers and stock studs | abutterman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 07-17-2013 10:55 PM |
