Drives: 2015 Scion FRS Auto
is e85 feasible in my area?
I am still really new to the club but I am super fascinated with the car and its potential. After seeing so much on e85 and the power that it can hold, I am really interested in getting it down the line. However I see a problem I expect a lot of others may have and I want to know whether they just ignore it and stock up or what their route is. The nearest e85 gas station is 17 miles away, aka there and back would cost almost 1/4 of a tank. In this case, is e85 just completely unfeasible or what?
Just run a flex fuel set up so you are never stuck.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (07-14-2019), NARFALICIOUS (07-13-2019) |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
They may add/remove pumps in the future.
I use the AFDC site to find stations. it was good when I took a cross country trip, there was a big 350+ mile gap in my route. https://afdc.energy.gov/stations/#/f...arest?fuel=E85 You can either: - Get a flex fuel kit or - Have a tune loaded up for 93 and one for E85 so you can switch out if things don't go as planned.
NARFALICIOUS
Noob Poster 1988 | 2016 |
#4 | |
#5 | |
If you are going to put an aftermarket catless header on you car, it would benefit from some sort of tune. There is lots of good information on this forum, try searching using google and preface your search with - FT86club. Before you start messing with the car their is a couple of considerations: * how will your messing effect the warranty? * renewing the re-registration your car with the DMV? I would recommend that you just put a cat-back muffler on and leave the rest of it alone - humfrz |
Drives: 2013 Ultramarine Scion FR-S
Where do you live in jersey? Im in Essex county so nearest one to me is Newark Airport, consider buying a few gas cans if you dont want to make the daily trip, ive seen a few people set up a 55 gallon drum in their garage and order fuel from shops also.
Also, i recommend you get comfortable with the car first. Personally, i got wheels and tires first, plus winters on my stocks, and then coilovers. IMO that makes the biggest difference in both handling and appearance Dont forget that this is your car and you dont have to listen to anyone on these forums (except for humfrz! listen to him) but in a reality do what makes you happy |
| The Following User Says Thank You to Little Mt. Fuji For This Useful Post: | humfrz (07-14-2019) |
#7 | |||
Also to answer your question OFT has a flex fuel kit available now so I don't see why not. For the N1 only there really isn't a need for a tune. For the headers they definitely need a tune. Also even the stage 1 tune is a bit more peppier and has better performance even with a simple catback with the n1. I would get the n1 and OFT first so then you can dabble in e85 if you feel like it.
#8 | ||
| The Following User Says Thank You to iconic For This Useful Post: | humfrz (07-14-2019) |
In reference to FRSBRZGT86FAN, I think this will be the first step for me honestly. I didn't learn about the OFT flex fuel kit until today.
#10 | |
#11 | |
humfrz |
#12 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Little Mt. Fuji (07-14-2019) |
#13 | |||
Since it sounds like cost is a big factor, the way I would go about it, is Tires-->OFT-->Header-->Catback-->Flex Fuel Kit. When I started modding my car, I lived in Arizona so i actually got OFT & Header at the same time instead of tires. However I grew up in Chicago so I know how important good tires can be. I've missed class before because my brand new FWD Civic couldn't go up a slight incline with snow ![]() The catback requires the least work to get going which is why a lot of people get it first, but it is the least effective if you are looking for a little more hp. Believe me though, while E85 & Header will make the car feel GREAT especially if done at the same time, you will still not be beating anyone around town, it's still only 190-200whp. The car would be great for track & autocross events though =) And personally, the reason I would save flex fuel kit for last is that I have pumps very close to me with E85 (and all are at least 70% ethanol) so I rarely have to change out. But, if I have to switch back to regular gas, the OFT allows you to save up to 5 tunes on it which can be uploaded to your car in about 10 minutes (find the threads on here on how to do it). I currently keep the v4 Gas, v4 E85, v4 Gas + Pops, and two v2 tunes because i don't have anything else to keep.
NARFALICIOUS
| The Following User Says Thank You to NARFALICIOUS For This Useful Post: | humfrz (07-14-2019) |
#14 | |
Drives: WRB Subaru BRZ Limited 6MT
But, of course, you can always fill a fuel can to help extend your range if the station is truly out of your way. Or run some intermediate mix of E85/93 to boost range while retaining most of the added performance benefit of E85. On straight 93, I will get between 340-360 miles on a tank at highway speeds (80 mph). I have no idea what my fuel economy is in the city on 93...I almost always switch to E85 when in the city. |
| CT Area- Looking for a great detailing shop in the area | Phothiraj | NY / NJ / CT / PA | 5 | 10-14-2013 02:37 AM |
| any weekly meets in the queens area or long island area | subyboy | NY / NJ / CT / PA | 23 | 08-26-2013 07:51 PM |
| New to the Area. | 86Trueno | Northern California | 5 | 07-19-2013 09:33 AM |
| Feasible light weighting. | Adeets | Engine, Exhaust, Transmission | 30 | 02-17-2013 05:29 PM |
| 2 car setup...feasible? | mankarn86 | CANADA | 3 | 03-30-2012 03:00 AM |
