Old 07-13-2019, 03:16 AM   #1
kev0
Drives: '14
2014 weird RPM behavior when braking (Automatic)
https://streamable.com/qg8a8
Does anyone else's AT behave like this? Mine never did this when on OFT OTS tune. Only started acting like this when tuned with Ecutek and SC install.
When coming to a stop, my RPM's will dip to ~490 then instantly shoot back up to ~730 a second later. When it dips, my car will shake a bit until it shoots back up. It even gets to the point where my oil light will flicker. I've checked my oil every time I come home and it's at the correct amount;even went to get it changed to 5w-30 yesterday and it still happens.
In the last second of the video, you can see what I'm talking about. Is this something that a tuner can smooth out or is it not possible? I've talked to my tuner about it and he keeps adjusting the tune but it's still persistent. It ONLY happens when I'm braking. RPM is normal and doesn't fluctuate when in park.
kev0 is offline   Reply With Quote
Old 07-13-2019, 04:15 PM   #2
ftpwny
Drives: 2013 Subaru BRZ
This happens to me as well with my 2013 6AT on OFT stage 2 catted tune and the Wayno tunes.
It only happens under hard braking and i can reproduce it pretty easily. There have been 2-3 times I actually had to brake hard and have actually had the engine stall completely. Super annoying.
Sent from my Pixel 3 XL using Tapatalk
ftpwny is offline   Reply With Quote
The Following User Says Thank You to ftpwny For This Useful Post:
kev0 (07-14-2019)
Old 07-13-2019, 06:21 PM   #3
86TOYO2k17
Drives: 2017 toyota 86
Not Normal. Did you get all your leaks sorted out and your LTFT and STFT sorted? They should not be a combined value of more then +\- 10% otherwise either MAF needs scaling, or most likely you still have leaks. Which would correlate to RPM drop
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
kev0 (07-14-2019)
Old 07-13-2019, 08:33 PM   #4
Lantanafrs2
Drives: 2013 frs red
Vacuum issue?
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
kev0 (07-14-2019)
Old 07-14-2019, 06:32 AM   #5
steve99
Alter the overun fuel resume table to resume fuling a a slighly higher rpm.
Adc 50 rpm to base ilde tables as well
Old 11-01-2019, 01:21 PM   #6
ftpwny
closing the loop on this. I cleaned my throttle body with CRC throttle body cleaner and that resolved my issues. Might be worth trying if you're still running into this.
Old 11-01-2019, 01:22 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have a bone stock 2013 AT, I have had this happen too.
I LIKE TIRES!
Old 11-01-2019, 02:17 PM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
My car did it stock and after tune. I know mine does this when the AC compressor kicks on.
Is that what's happening to yours?
EDFC behavior and initial values for automatic dampening killy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 07-24-2018 03:16 PM
Weird behavior and some Interior lights not working TorontoNat Electronics | Audio | NAV | Infotainment 5 02-15-2018 09:13 AM
Weird sounds out of gear w/ AC - 2014 BRZ SmartedPanda Issues | Warranty | Recalls / TSB 9 07-15-2017 02:59 AM
Weird mac valve behavior mhiscott Forced Induction 2 10-08-2015 05:44 AM
Stock 2014 is headunit acting weird Thehermdawg Electronics | Audio | NAV | Infotainment 0 05-26-2015 05:35 PM
