Old 07-11-2019, 11:03 PM   #1
robertplas
Drives: 2013 frs
Rear view camera
So I tapped into the reverse trigger wire from the fuse box and I don’t find where to tap the cameras red wire
robertplas is offline   Reply With Quote
Old 07-11-2019, 11:03 PM   #2
robertplas
Drives: 2013 frs
I’ve already looked at others but it wasn’t helpful to me
Old 07-11-2019, 11:05 PM   #3
robertplas
Drives: 2013 frs
This red wire is what’s confusing me I hooked it up to the purple wire but nothing, reveres comes into play just shows a black page
Old 07-11-2019, 11:10 PM   #4
Trist0n
Trist0n's Avatar
Drives: FRS 10 Series
Sounds like we can rule some things out then. A black screen when shifting into reverse means that the head unit is properly receiving the signal to switch to video input mode upon receiving power, so that part of the wiring is right, but there’s no video to display. This means that either the camera isn’t receiving power, or just not transmitting a video signal properly into the head unit.
Trist0n is offline   Reply With Quote
Old 07-12-2019, 03:49 AM   #5
ScionWolf
Drives: '13 Scion FR-S
If I recall correctly, the red wire just needs to be attached to a switchable power source. Reverse light for example. Been so long since I've done mine, I can't remember where I finally hooked it up, but I know that's what I did to test it and verify the camera works.
ScionWolf is offline   Reply With Quote
Old 07-14-2019, 10:09 PM   #6
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
6V power
I hope its not too late but if you're using the factory camera DO NOT connect the camera directly to a 12V source like the reverse lights! You'll most likely kill it. You're supposed to use something like a buck converter to step it down to 6V. I've installed an aftermarket head unit in my 2016 FR-S and I had to use a step down converter. You most likely will need to use one also.
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Rear view camera Sasquachulator Scion FR-S / Toyota 86 GT86 General Forum 10 08-20-2018 08:52 AM
I need help about rear view camera bartuc Electronics | Audio | NAV | Infotainment 3 11-26-2017 09:03 PM
Rear View Camera *Fail* FNCrazy Electronics | Audio | NAV | Infotainment 6 07-24-2016 08:48 PM
stock brz jdm rear view camera SuperDave Electronics | Audio | NAV | Infotainment 0 04-03-2014 09:53 AM
be spoke w rear view camera xpicer Electronics | Audio | NAV | Infotainment 17 10-14-2012 09:26 AM
