Old 07-11-2019, 02:50 PM   #1
jc7993
Drives: Looking to buy
UEL Header and Exhaust
My plan regarding the exhaust setup is to have a 1320 Performance UEL header with the 60mm overpipe and have it connect with the MXP SP quad tip catback exhaust.
My concern with this setup is potential fitment issue that with this combo. Anybody that has this setup that can chime in with their experience?
Is there any other parts that I need to buy besides the accessories included with the header?
Much appreciated!
jc7993 is offline   Reply With Quote
Old 07-11-2019, 06:38 PM   #2
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
What you need to find out is whether or not the front pipe you're using will fit. If it's stock I don't see why it wouldn't, however.
MCTeeJ is offline   Reply With Quote
Old 07-11-2019, 07:49 PM   #3
Prodigalson
ThisGuyLoves86's
Prodigalson's Avatar
Drives: 2013 Scion FRS
I just listed a 1320 Performance overpipe and front pipe on eBay. $50 shipped for the over pipe and $100 shipped for the dual resonated front pipe. Both include the original unused gaskets and hardware.
2013 Scion FRS (current car)
1991 Mazda Miata MX5 (current car)
2003 Nissan Pathfinder (R50) (current car)
2018 Lexus GX460 (current car)
2023 GR86 Neptune M6 Premium (Leased)
Prodigalson is offline   Reply With Quote
Old 07-12-2019, 10:07 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Unless you want the UEL sound, I would rather gut the cat on the stock header then use the 1320.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
kch (07-12-2019)
Old 07-12-2019, 10:19 AM   #5
jc7993
Yes, I would like to keep the UEL sound. Hopefully the 1320 headers does not throw a code for the O2 sensor...
Old 07-12-2019, 10:30 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If it is catless, it will give you a P0420 for cat efficiency. Before you buy a catback just pick up an OFT. I bet there is 1, or 3 in BST right now. You won't be getting much benefit from your exhaust upgrade without a tune and the tune will disable the CEL for cat efficiency.
jc7993 (07-12-2019)
Old 07-12-2019, 01:34 PM   #7
jc7993
I believe that this header is catless. So I'm guessing that it most likely will throw a code...
Old 07-12-2019, 02:16 PM   #8
kch
Senior Misanthrope
kch's Avatar
Tune it. That will fix the code and get you the full benefit of the header.
SRT full header back exhaust + header? KenTK808 Engine, Exhaust, Transmission 21 11-29-2017 05:07 PM
FS: OEM Exhaust, Header wahsaihin Canada Classifieds 1 07-20-2015 02:02 PM
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
The Exhaust Diet: Lightest Header to Exhaust tip combo phastafrican Engine, Exhaust, Transmission 3 12-30-2013 08:44 PM
