Old 07-05-2019, 09:33 AM   #1
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Fifteen52 Tarmacs: 17x9 +30 ...clearance?
I picked up some scuffed up Fifteen52 Tarmacs in 17x9" +30 at World's Biggest Meet at Stafford Motor Speedway this weekend for $600, and I'm worried about the lower offset. I love a little bit of poke and I'm on stock suspension for now, but with a 245 tire am I going to rub? Any rub concerns once I drop an inch or two on coilovers? Enough that I should consider going 235?
Car is daily driven mostly on the highway, not looking to eat through wide soft compound tires with crap mileage. Any suggestions on tires for this setup would be much appreciated. Anybody else running tarmacs?
majixmatrix is offline   Reply With Quote
Old 07-05-2019, 11:48 AM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
Use the wheel it fit calculator, top of this section in a sticky.
17x9 +30 with -1.8 degrees of camber or so will be flush-ish in the front at stock height. You'll need more camber or narrower tires the lower you go.
Rear won't be any problem.
maslin is offline   Reply With Quote
Old 07-05-2019, 12:48 PM   #3
scotto79
Drives: 2016 Ablaze FRS
I'm running 720Form GTF1s in the 17x9 +35 with the stock summer tires (215/45r17) stretched a bit. They fit fine on stock suspension until I actually buy the car when my lease is up, then probably BC coilovers.
scotto79 is offline   Reply With Quote
+30, 17x9, fifteen52, tarmac
RCE Tarmac 2/17x9 RPF1 Clearance? hukdizzle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-21-2019 04:53 AM
Fifteen52 Tarmacs 17x9 5x100 aLaFleur Wheels and Tires 5 02-15-2015 12:00 AM
FS: fifteen52 f40 forged tarmacs spitfire481 Wheels and Tires 39 12-05-2014 12:51 PM
FT: fifteen52 forged f40 tarmacs spitfire481 Wheels and Tires 10 03-30-2014 12:38 PM
FT: 17x9 +40 Fifteen 52 Tarmacs dminner Wheels and Tires 6 04-18-2013 10:57 PM
