Old 07-03-2019, 10:46 PM   #1
trev616
Drives: 2017 Toyota 86
On board data
Are there and units that not only can play music and all that but also display onboard information about the car like oil temps, water temps, fault codes, that kind of stuff? Radios and head units are probably what I know least about with these things so I don't even know where to begin
trev616 is offline   Reply With Quote
Old 07-03-2019, 11:04 PM   #2
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Yes, there are a couple of directions to go to accomplish this. You can buy an Android based head unit and use a dongle that attaches to the OBD2 port in the car to beam information to the head unit.
You can also buy a head unit that is idatalink Maestro RR compatible (check their website for model compatibility info) and use a harness that connects between the OBD2 port and the back of the head unit. This option is what I chose to do with a Pioneer AVH-2330NEX and Maestro RR combo and I am able to read various engine parameters such as oil and coolant temps, EGTs, etc. as well as TPMS data including tire pressure and temperature.
NCtoBRZ is offline   Reply With Quote
Old 07-15-2019, 10:19 PM   #3
KVDB31
KVDB31's Avatar
Drives: 2013 FR-S Asphault
Thanks for the lead about the Maestro unit, that looks awesome!
Does it read oil pressure, oil temp, and trans temp?
TSW Nurburgring 18x8, BFG Comp-2 235/40, KW V3's w/ Vorshlags, ECUTek by Evasive, Injen intake, FT86 Header, Motiv OP/DP, Nameless Axleback, 4.88 Weir gears, Subaru Legacy GT brakes, Five Axis spoiler, Shark Fin, 3000k HID's, LED goodies
KVDB31 is offline   Reply With Quote
Old 07-16-2019, 08:20 AM   #4
ka-titties
Drives: 2013 BRZ Limited 6MT
Its limited to what the ECU has inputs for.
ka-titties is offline   Reply With Quote
Old 07-16-2019, 09:21 AM   #5
wparsons
wparsons's Avatar
Definitely won't do oil pressure, the cars don't have oil pressure sensors stock. Not sure about a trans temp sensor, but I wouldn't bet on it. Oil temp should be easily handled by it.
flickr
Old 07-16-2019, 08:16 PM   #6
KVDB31
KVDB31's Avatar
Thanks for the responses guys.
Is there a list of what live data is readable via OBD2 on these cars somewhere? I started my search for that and ended up on this thread.
Equivalent WRX message Board? Breeeep Other Vehicles & General Automotive Discussions 36 09-02-2016 01:08 PM
Help with shortening led circut board MemphisR Cosmetic Modification (Interior/Exterior/Lighting) 14 03-04-2016 03:30 PM
Are you on this board? Whose car is this? inertia BRZ First-Gen (2012+) — General Topics 9 12-09-2015 08:19 PM
Does anyone surf? How are you transporting your board on your FRS/BRZ? RYU BRZ First-Gen (2012+) — General Topics 17 01-05-2015 10:27 PM
