Old 03-03-2016, 01:51 AM   #1
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Help with shortening led circut board
Hello All,
I am looking for help from anyone that has some wiring expertise and tell me or help me figure out how to shorten this LED board. I am making a custom high mount, but this one board is too long. I have noticed that on each board, there are 12 LEDs and 1 resistor per every 4 LEDs. Please help me figure out how to eliminate the last group of four LEDs from the end of the board.
Thanks,
MemphisR
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 03-03-2016, 11:55 AM   #2
Ashikabi
Ashikabi's Avatar
Originally Posted by MemphisR View Post
Hello All,
Thanks,
MemphisR
I'm no expert but I think they just run in a line, should be able to just cut the 4 off the end and solder wire leads to it. FYI there is a high mount kit available for the 05/09 mustang from Classic Design Concepts for about $50 that fits well. Good luck with your project
Old 03-03-2016, 12:12 PM   #3
jvincent
jvincent's Avatar
It's hard to make out from the picture put if the power tracks go to each resistor/LED group in parallel, then all you need to do is cut the board AFTER the last group you want to keep and you should be fine.
If they are wired serially then after you cut you will need to add a jumper wire to complete the circuit.
A parallel circuit would be the safe assumption since that would mean any single failure wouldn't take out the whole strip.
Old 03-03-2016, 03:20 PM   #4
MemphisR
Memphis
MemphisR's Avatar
I am familiar with that kit, but they don't make a full width one
Old 03-03-2016, 03:21 PM   #5
Ashikabi
Ashikabi's Avatar
Use 3? Jk want sure if you needed custom or just didn't know
Old 03-03-2016, 03:26 PM   #6
MemphisR
Memphis
MemphisR's Avatar
I tried it after removing the end four LEDs, nothing. I then added a wire jumper from the middle two wires/leads and still nothing...with the exception that I blew a fuse.
Thanks for your help
Old 03-03-2016, 03:31 PM   #7
Ashikabi
Ashikabi's Avatar
Did you cut it right at that hole? It really looks like it should have worked... you didn't hook it up backwards did you? I think LEDs are 1 way
Old 03-03-2016, 03:45 PM   #8
MemphisR
Memphis
MemphisR's Avatar
I did uct it off at the hole. I also tried it both ways.
Old 03-03-2016, 03:48 PM   #9
jvincent
jvincent's Avatar
Where exactly did you put the jumper that blew the fuse?
If you can get a higher contrast picture of the back of the board it would help. Or better yet, the schematic.
Old 03-03-2016, 03:51 PM   #10
MemphisR
Memphis
MemphisR's Avatar
The second hold from the right it were i attached the jumper and it was attached to the two middle wires/leads. I will take better photos tonight, and try to find the schematic as well
Old 03-03-2016, 03:54 PM   #11
Ashikabi
Ashikabi's Avatar
As far as I can tell there are just 2 wires there. Shoulda worked. Eager to see how this gets fixed
Old 03-03-2016, 04:02 PM   #12
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
You should try to post on the retro fit source forum. Those dudes know all there is to know about lighting.
Old 03-03-2016, 04:04 PM   #13
jvincent
jvincent's Avatar
I can't be 100% sure since the tracks on the board aren't clear, but I think you shorted the power supply with that wire, which would explain the fuse blowing.
Old 03-03-2016, 07:17 PM   #14
mabviper
Drives: WRB BRZ
I looked at the PCB. You should cleanly cut the board on the 2nd hole from the right. Don't short any wires since the 2 leads are power and ground. That'll cause the blown fuse. It should just work as is. The circuit is connected as 3 parallel led strings. Each led string is connected in series. Hope that helps.
Sent from my Nexus 4 using Tapatalk
mabviper is offline   Reply With Quote
Are you on this board? Whose car is this? inertia BRZ First-Gen (2012+) — General Topics 9 12-09-2015 08:19 PM
Norcal86 Board and feedback. finch1750 Northern California 8 02-10-2015 02:12 PM
Anyone interested in trying a new board game? darkonion Northern California 4 10-20-2014 01:10 PM
When is this board going to get a Swap forum? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 1 06-12-2014 01:24 PM
