Old 07-02-2019, 03:06 AM   #1
kev0
Drives: '14
P0304. Leak somewhere or bad spark plugs/coil packs?
P0300 and P0304 code. P0300 went away after I cleared it and haven't came back. The P0304 stayed even though I cleared it 5x.
I got the codes after installing my tune and SC. These codes were not there before. Could it be possible that my coils/plugs broke the day I start up my car for the first time since the install? What are the other culprits? Could it be the DI seals? I mean, there has to be a HUGE coincidence for these parts to break right when I finished installing the SC.
Car hesitates to start up. When the car eventually starts up, it sputters and RPMs drop really low, sometimes low enough to for the engine to cut out. Can a leak cause all of this and throw off misfire codes? Is it possible for the spark plugs or coil packs to be completely fine even though its throwing a misfire code? My tuner is adamant about a leak somewhere but I just want to get second opinions.
Data logs: https://datazap.me/u/kev0/p0304
kev0 is offline   Reply With Quote
Old 07-02-2019, 04:20 AM   #2
tomm.brz
Drives: brz 2017 hksv2
its just a leak somewhere, check hoses under the intake manifold
Old 07-02-2019, 05:32 AM   #3
kev0
Drives: '14
You're certain that it's a leak somewhere right? Because that's what my tuner thinks too. I'll check the intake manifold tomorrow. It was a Sprintex 210 kit that I installed.
Old 07-02-2019, 07:15 AM   #4
tomm.brz
you NEED to clamp those hose or they pop out first time you turn on the engine, if your installer didnt do it/know it, that isthe problem
Old 07-02-2019, 07:15 AM   #5
tomm.brz
and check also if there are leaks around first lambda
Old 07-02-2019, 07:31 AM   #6
kev0
Drives: '14
Certainly hoping this is the case. I clamped EVERY hose but the ones under the intake manifold.
Old 07-02-2019, 09:34 AM   #7
maslin
Benz Tech
Drives: 2017 BRZ Premium
No one can be certain about your car that they aren’t even looking at.
Maybe the piston cracked? Maybe the head gasket let go? Maybe a coil failed? Maybe the DI computer failed? Maybe it’s just a hose off?
P304 is just cylinder 4 misfire. Absolutely no indication of a cause. Air, fuel and compression, one is off.
maslin is offline   Reply With Quote
Old 07-02-2019, 09:59 AM   #8
tomm.brz
agree
but he just god super high positive fuel trims after the install, difficult that it is something else other than a vacuum leak
IP Coil Packs bozack Engine, Exhaust, Transmission 6 03-06-2022 01:36 PM
Stock 13/14 coil packs shaynek Want-To-Buy Requests 1 04-26-2018 08:20 AM
4 OEM spark plugs and 1 OEM ignition coil Kronos Engine, Exhaust, Bolt-Ons 12 07-29-2016 10:08 AM
Do I have bad coil packs or a failing DI pump? xkalelx Forced Induction 16 03-15-2016 01:56 PM
Is $460 too much for 1 oem coil pack & spark plugs from mechanic? spatcha88 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 03-21-2015 12:08 PM
