Can you recommend good shocks/struts?
Hi Guys!
I'm thinking to get either Eibach Pro kit or sportline to lower my car (probably Pro kit). At the same time, I'm trying to replace shocks/struts too (since I have a bouncy ride after accident). Can you please recommend good shocks/struts that will be a good match with Pro kit? |
Drives: 2017 BRZ PP , 2005 Saab 97X
Purist
Drives: 2013 FRS - Hot Lava
My vote, find a set of used BRZ Sachs struts. But something like Koni or Bilstein would suit a lowering spring better.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Find some Sachs from a performance package BRZ. I'm sure you can get them cheap from someone who already swapped to coilovers.
Guys,
I have a newbie question. I have 2018 BRZ performance package, and it seems like PP Sachs are same as the shocks/struts (functions same?). And, I can replace Sachs/shocks/struts to Coilovers?? So should I just get coilovers instead of purchasing springs (to lower car) + shocks/struts because it will cost about the same?? Eibach springs + shocks/struts will cost around $600, and coilover is around $700-800 Last edited by mitama; 06-28-2019 at 05:28 PM. |
Drives: 2013 Scion FRS 6-speed
Don't mess around, get you some tein flex z. Good quality, affordable price. I've had mine for about 50k miles, no issues. Plus you can adjust the height to your liking whenever you want!
Sent from my SM-G892A using Tapatalk |
Purist
Purist
Sachs struts are a factory upgrade to the normal BRZ, they will fit factory springs. Think TRD parts. They are not better than a Koni. You posted you have a PP BRZ with Sachs? Then just get springs or go Coilovers. Springs: $300? Coilovers: $900?
#10 |
SO...can you please confirm all I need to lower my car + fix my struts/shocks will be a coilover?
#11 | |
Correct me if I'm wrong. |
#12 | |
Should I get coilovers to lower my car and replace damaged struts/shocks? |
#13 | |
Purist
#14 | |
so I might choose coilover although I'm not sure I'm going to get the tein. |
| OEM springs/struts/shocks | bfrank1972 | Brakes, Suspension, Chassis | 19 | 01-29-2019 10:03 PM |
| Bilstein B6 Shocks/Struts Set | simpleisbest | Brakes, Suspension, Chassis | 6 | 06-08-2017 08:14 PM |
| FS: NJ Stock shocks/struts | Joon525 | Brakes, Suspension, Chassis | 2 | 03-08-2017 12:08 PM |
| WTB - Front OEM Struts/Shocks for BRZ | Jawnathin | Want-To-Buy Requests | 3 | 05-05-2015 08:36 PM |
| What shocks would you recommend? | CaptainSlow | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 01-31-2013 01:18 PM |
