Old 06-26-2019, 03:40 PM   #1
Icecreamtruk
Drives: Track preped NA FRS
Change to clutch pack LSD or not
So I have a problem that I dont really know how to address but Im leaning towards a clutch pack LSD being the solution.
Basically, the car is kind of stiff (12k springs all around), has quite a bit of aero (estimating around 400-600lbs total or something in the ballpark of that), stock power, entry level R compounds levels of grip tire wise.
On to the problem itself, when the tracks are smooth, its mostly fine, but on some turns, or in really bumpy tracks, when the car hits a bump as I start to accelerate or if I hit the kerb too hard the car will struggle to accelerate smooth and just go up and down in rpm, which Im assuming is the inside wheel spinning freely, or close to anyways. When it does so, the car understeers on turn exit instead of getting the nice rotation I like so much when its just sliding both tires towards the exit. When this problem doesnt happen, I can take most turns with very little steering input and have to even add a bit of counter after I hit the gas, but when the stuttering happens its just understeers and I usually just have to back off or dab the brakes a bit to not run out of track.
The car doesnt lack power to spin both wheels on corner exit, provided im at the very edge of traction, I think with even half the power I would still slide the rear on corner exit, but it only happens on smooth tracks, on bumpy tracks corner exits are frustrating and filled with transitions between under and over as if the car is suddenly losing half its power. What I think the solution is going to be is a clutch pack diff, thinking of an OS-giken specifically. To have both wheels get all of the power all the time, regarding of one being 1 foot in the air or not.
What do other people who have been down this path already think? Am I on the right track? I havent really experienced this before so Im not sure if it is what I think it is. In the ruleset that we use, there is no difference between a torsen or clutchpack type diff, so I would incur no penalties for switching out, so if there's time to be found there, Im totally taking the dive. I know this problem can be driven around, but I'd rather solve and find time if at all possible.
Old 06-26-2019, 04:07 PM   #2
Datalog it.
You have enough equipment where you should have a datalogger. Verify the problem before committing to a fix you may or may not need.
Icecreamtruk (06-26-2019), wparsons (07-11-2019)
Old 06-26-2019, 04:20 PM   #3
Icecreamtruk
Datalog it.
Working on it, should have something up with ECU + GPS logging and video to correlate, I should have it before the 6th july which is my next day out at the track. What should I be looking at appart from the classic throttle, brake and steering input? Individual wheel speeds? Is it possible to get that over OBDII?
Old 06-26-2019, 04:43 PM   #4
Racecomp Engineering
For the problem you are describing, I would want shock position sensors in addition to the usual obd2 data.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Old 06-26-2019, 05:05 PM   #5
I just want wheel speeds, really. Available via OBD2.
[ame]https://www.youtube.com/watch?v=9Jw0yeTx0Ig[/ame]
numbers on bottom right are wheel speeds.
Front Left, Front right
Rear left, Rear right
Observe the rear wheel speed differentials to see when the stock torsen is behaving like a limited-slip, vs open diff.
Icecreamtruk (06-27-2019), wparsons (07-11-2019)
Old 06-26-2019, 06:26 PM   #6
Evan55
Drives: 06 Exige, 17 BRZ PP
If your shocks arent keeping the tires on the ground, it would have the same symptoms, and if you say it happens when the track is bumpy but not smooth, thats would back up that hypothesis.
I would look into shock tuning first
Evan55 is offline   Reply With Quote
The Following 4 Users Say Thank You to Evan55 For This Useful Post:
Icecreamtruk (06-27-2019), Racecomp Engineering (06-27-2019), Tristor (06-27-2019), Ultramaroon (06-26-2019)
Old 06-26-2019, 08:51 PM   #7
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I need this video overlay in my life. How do you achieve this?
PRO86 | WTCC | STL
Old 06-26-2019, 10:03 PM   #8
Race Render. Additional overlays done in Premiere.
http://racerender.com/Products/index.html
rice_classic (06-26-2019)
Old 06-26-2019, 10:09 PM   #9
rice_classic
What are you using for data logging that you import to racerender?
PRO86 | WTCC | STL
Old 06-26-2019, 10:10 PM   #10
Aim Solo DL
Old 06-26-2019, 10:37 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
Or one could just listen to their engine and deduce the cause for free.
OP, are we talking about washboard like 10 Hz or wavy, say at 3? Could you get away with less rebound damping? I'm with Evan55.
Old 06-26-2019, 11:19 PM   #12
Can you listen to the engine in my video, and tell me when there's a single rear tire spinning?
Old 06-27-2019, 12:00 AM   #13
Ultramaroon
not playing cards
No but OP can hear his so he's working on a way more obvious issue. He doesn't need that kind of sensitivity. How on earth did we ever tune suspensions before the days of electronic gizmos?
edit: actually, I went back and realized why I didn't hear anything. I turned off the sound as soon as I heard that painful intro music. Even in yours there were a few places where it was pretty obvious.
edit 2: And sound is not all of the story. The feels are important too. You know there's a difference between engine surge mid-corner with outside wheel hooking versus surge from lofting.
Icecreamtruk (06-27-2019), venturaII (07-11-2019)
Old 06-27-2019, 12:24 AM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
Why are you running such stiff springs? Are you trading off for not running a sway bar or something?
FS: SSP AT Clutch Pack! NIB nlowell Transmission and Driveline 14 01-16-2022 09:38 PM
SOLD: OEM Clutch, Pressure Plate, Clutch Fork and Pivot, Exedy TOB zc06_kisstherain Transmission and Driveline 3 10-17-2018 10:31 PM
Won't start after clutch change RenegadeReaper Issues | Warranty | Recalls / TSB 21 09-19-2018 09:21 PM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 07:27 PM
