Old 06-19-2019, 06:08 PM   #1
Decep
Drives: 2013 FR-S Series 10
For those who've had TOB replaced
Im almost at 50K miles on my 2013 and i've had the sewing machine type whining at idle for maybe 15-20k miles from the TOB. No grinding or other weird noises on startup.
Recently, maybe within the last 600 miles i've had this kind of rattling, maybe somewhat marbles in a can sound at around 2000-2500 rpm, in gear, cruising along at street speeds like 30-45 mph.
It goes away at the slightest of clutch inputs (even just depressing the clutch a few mm). Safe to say this is the throwout bearing really starting to give out and i should book an appointment asap?
Old 06-19-2019, 06:31 PM   #2
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
TOB symptoms can vary, typically it is occurs when the clutch is pressed on a cold start up, but like I said others have had different symptoms. At 50k I think it would be a good idea to get the TOB done just in case. If left unchecked a gone TOB will cause further more expensive damage. New TOB part is also supposed to have better life. I suggest you do a google search for "FT86club TOB throw out bearing" and consult the wealth of info on this forum which should help you find everything you need to know.
DandoX is offline   Reply With Quote
Old 06-19-2019, 06:44 PM   #3
Decep
Thanks, just hadn't heard of anyone's making a noise like mine is. I do know they make a real mess when they go.
Old 06-19-2019, 06:45 PM   #4
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
from new to 40 K miles I had no clutch problems...then from 40 to 50 K my pedal started feeling heavier and mushier especially on start up (though after everything warmed up it would actually go back to being pretty perfect) and then sometime soon after I hit 50 K, I started getting the high pitched whine that I assume you're referring to and I got it replaced right away..back to perfect now
HKz is offline   Reply With Quote
Old 06-19-2019, 07:38 PM   #5
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Check out my build. The snout/snorkel can get ruined if you wait too long until it finally fails like I did. It isn’t too expensive, but still.
Old 06-19-2019, 08:09 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
My TOB was making like a roller skate type of sound at 60k miles it finally went out at a Taco Bell drive through. It made a horrible metallic grinding sound, couldn't get past second gear cause it was dead.
The longer you wait the more costly it's going to be. Lucky the shaft he TOB rides on wasn't totally fucked, but it need a good polishing
Long story short the sooner you fix it the happy and worry free your drive will be.
Old 06-19-2019, 08:54 PM   #7
humfrz
You REALLY ate that stuff? -
humfrz
Old 06-19-2019, 09:36 PM   #8
jflogerzi
jflogerzi's Avatar
Mine went completely toast at 63k on a 2013. Now the question is should you replace the clutch? I did because I was close to 225-250wtq and our stock clutch is not rated for that much power. But at 40 you should still have plenty life in the stock clutch
2013 Series 10 FRS #553
Old 06-19-2019, 11:01 PM   #9
Decep
I may as well, why not.
Old 06-19-2019, 11:10 PM   #10
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
humfrz
Only when I feel suicidal. Or when I want to punish someone's toilet
Old 06-20-2019, 10:42 AM   #11
radroach
Drives: car
@Decep Here's what my TOB sounded like after 50k miles (105k miles on the car).
https://streamable.com/0ka17
Had it replaced last week and it sounds much better.
Old 06-20-2019, 02:48 PM   #12
Decep
Did it make that noise in gear and driving around too? It sounds similar but mine does it through all the gears , under light loads
Old 06-20-2019, 03:27 PM   #13
radroach
Drives: car
@Decep Yes I had the sound in gear. I couldn't hear it when it was cold, but when it got hot it would knock badly.
TOB sounds vary though depending on how much wear they have. Sometimes they might make a shh-shh noise, or they might make a grinding sound in decel, or in this case a random tapping / clacking.
As for your question about needing to take it to a shop, I'd try to fit it in with a spark plug change or clutch job / upgrade. If you can find a reputable dealership to do valve spring recall (as I know this is more of an issue with Toyota owners) it can be done more conveniently.
Old 06-21-2019, 06:49 AM   #14
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Might as well upgrade everything, fork, clutch, flywheel, everything you can in the transmission.
Clutch Replaced StOpNG0x Engine, Exhaust, Transmission 46 08-31-2016 01:35 AM
Should I get my HPFP replaced? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 25 04-08-2015 07:52 AM
Had to get one tire replaced, where to put it? malave7567 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-29-2014 06:33 AM
Chirp Gone Nothing Replaced Employee CANADA 6 08-04-2013 12:25 PM
